Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Bumped into my junk spare Superram setup today... Project!
Old Apr 22, 2012 | 05:38 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Had this crap sitting in my closet for the last year. Getting tired of bumping into so I figure I will start working on it... especially after seeing this auction. Value is starting to look good on these!
http://www.ebay.com/itm/140739028783...#ht_500wt_1093
This stuff has oil blow by stains, the runners were painted horribly (paint inside and outside of the runners), Intake is nice but used, TB is dirty and old... and so on.
I pieced this setup over about 2 years or so... I am amazed I ended up find the runners to be honest. I got a great price on everything too!
I bought a Craftsman 1/4 sheet sander at the BX today for like 20 bucks. Progress pics will come!
Anyone have any suggestions for a paint/polish scheme or anything? This is my spare setup that will go on the car when I go to port the stuff on my car currently. I'll post pictures as I go along with before and after pictures. Should be a fun little project!
Feel free to subscribe, comment, make suggestions... Enjoy!
Old Apr 23, 2012 | 05:36 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Bumped into my junk spare Superram setup today... Project!
Well, I spent about 2 hours on the plenum today with the electric palm sander I bought. I have been using 60 grit... Here are some pictures of some progress.
Anyone have any tips for the runners? Or any tips to make this sanding any quicker? All the small pits in the casting are making this a huge PITA. I think I started with the worst cast of a superram ever...
If sanding is going to be this shitty, I may just clean the runners up with some steal wool and paint them.
Old Apr 23, 2012 | 06:22 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The casting and machining on the superrams were not too great. Looking good so far
Old Apr 23, 2012 | 06:30 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Thanks!
I know it doesn't look like I did too much, but here is a picture of what I started with.
And that was the smooth side...
Old Apr 23, 2012 | 06:40 AM
Engine: Lb9
Transmission: M20
polishing out those nasty casting put will take a while but nice gratification in the end. I wish I was fortunate to have a second superram Luck dog.
Old Apr 23, 2012 | 07:00 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I actually plan on polishing this one and using it for display until I pull my good superram setup to get fully ported and welded and everything, but that isn't planned for another year or two when I am living in the states again.
Old Apr 23, 2012 | 07:06 AM
Engine: Lb9
Transmission: M20
not too bad, wish I had a better lid for mine. You can still get the billet one but I wish it wasn't all smooth
Old Apr 23, 2012 | 07:14 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
You can buy new stock cast lids from Jonarotz. He works for accel I believe and there is a bin full of lids and plenums he is trying to get rid of. He doesn't have the runners though, I already tried... I went through him to buy the new plenum for the setup that is on my car currently. Then I ended up piecing everything together for my spare setup, but I didn't have a lid, so I just bought one from him to complete it. He is a solid guy to go through and I wouldn't hesitate to buy from him again!
I wouldn't mind a billet lid though, how much do those run?
Old Apr 23, 2012 | 07:21 AM
Engine: Lb9
Transmission: M20
$176.99 and ouch !!
http://sdparts.com/details/accel/acc74198
http://emracingcorp.com/scripts/prod...?idproduct=163
Old Apr 23, 2012 | 07:43 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Interesting. I wonder if they still stock them...
Old Apr 23, 2012 | 07:50 AM
Engine: Lb9
Transmission: M20
not sure , I still have a new lpe tb cover. I think lpe quite making them and a few 58mm lpe throttle bodies I got on the prestolite performance red racer deal.
http://www.spectergtr.com/mm5/mercha...gory_Code=C243
Old Apr 25, 2012 | 06:02 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Spent 2 hours on it yesterday, and an hour today. Still using the 1/4 sheet palm sander with 60 grit. It is looking much better. I need to work on a small section of it pictured, then I need to work on the area's next to the TB area by hand
Anyways, here are some updated pictures.
The area I need to work on...
Old Apr 30, 2012 | 01:44 PM
ericoo1's Avatar
Car: 89 silverado,02 s10 blazer
I don't envy you one bit. I went through the same thing a couple years ago and just ended up painting mine. That inside curve you have pictured was a nightmare to do by hand.
Old Jun 27, 2012 | 05:39 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Very difficult to do it the way you are
Starting with 60...ouch.
What Id do is keep going then get some nice paint/powdercoat on it.
Better equiptment you have easier it is, can start with much finer grits and skip steps. Adds up....
Old Apr 9, 2013 | 03:44 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Would you suggest using an orbital sander or something? I know the palm sander sucks!
Old Apr 9, 2013 | 02:36 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
http://www.cardomain.com/ride/245864...ans-am/page-2/
It is a lot of work to get the casting smooth and polished. I found a lot of cigars and beer make it go better! I am glad I did it though, I really like the look.
The end results will be worth it. Hang in there.
Old Apr 9, 2013 | 03:46 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That's the TB cover that the SR on my car came with... I had a custom one made though, but I haven't put it on yet. I will probably keep the LPE one though and see if it fits a stock TB.
Old Apr 9, 2013 | 04:00 PM
Engine: Lb9
Transmission: M20
Can't wait to see your pictures of the sr when you are done. Nothing like a polished sr
Old Apr 9, 2013 | 04:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Haha, won't be any time soon. I have a lot going on this year. I'll have some time when I get out of the military in 10 months...
And just so everyone knows, I haven't lost interest... I have just been swamped with car stuff.
Old Dec 7, 2013 | 12:49 PM
eastbayallday's Avatar
http://www.spectergtr.com/mm5/mercha...gory_Code=C243"
I know this is a old post but was wondering if you still had this item and if you would be interested in selling it?
Old Dec 7, 2013 | 01:04 PM
Jeffs82TA's Avatar
SR easy to polish, buy yourself a 1/2 inch belt sander and it will remove the pourus material easily. You can also buy conical sanding drums you use one a drill. I never go past 120 grit.
Start of a 3800 4th gen intake
Old Dec 15, 2013 | 09:11 PM
Axle/Gears: 4.11
Rough cast aluminum is a real betch you really need some decent equiptment to make it come out right. Those are old porous castings youll be an old man before they look decent....lol but it can be done. Not discouraging you just....be patient!
Polished a superram awhile back I cannot imagine doing it by hand.
Finished the below last night
Item 221332764744 on the 'bay site
Old Dec 16, 2013 | 05:57 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Just incase everyone thought I quit this project, I am here and that is not the case. I ended up deploying for 6 months, then have had a bunch of stuff go on... I was planning on getting out in January, but I got an assignment to England, figured since I had family there I might as well take it.
So since I have been stuck in the dorms and finding a place to work on it has been a PITA, I am going to wait until I get to England where I will be living off base and a bit more free to make noise with a sander and such.
Old Dec 16, 2013 | 06:02 AM
Engine: Lb9
Transmission: M20
Or you can send the sr to me lol, I wouldn't want to give it back though
The casting of the sr plenum I think is the worst casting I have ever seen. You just have to end up living with a bunch of pin holes all over. But the shine is nice.
Old Dec 16, 2013 | 06:12 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
If I end up with pinholes, I can deal with it... This isn't going to end up on my car, so it doesn't matter too much. I do need to downsize my collection after I picked up my Typhoon... I don't need 2 superrams sitting around, nor do I need to own 8 sets of wheels that aren't on my car... I have a huge list of stuff I need to sell, but it is hard from over the pacific... Lol
I'll be taking a bunch of stuff to England, so I can try to sell it when I get there and ship it back to the states or something. I will finish this though, so no worries there!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
SG91camaro
Sep 5, 2015 10:27 PM
