Z-06
Old May 7, 2002 | 08:37 PM
Sho's Avatar
Sho
Z-06
will any of the Z-06 17"x9.5",18"x9.5", or 18"x10.5" rims fit on a third gen?
Old May 7, 2002 | 09:51 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
i think so, with the right wheel spacers, you can buy Z06 rims in chrome and they look badass.
Old May 7, 2002 | 10:37 PM
Sho's Avatar
Sho
yeah thats what i was thinking....im just trying to decide if i can fit the 18"x10.5" on there and still have some space so the tires dont hit the car ya know? expensive as hell getting 4 new chrome 18"x10.5" rims....the dame things cost 344 apiece if i remember correctly...but it will look bad *** with my black and silver paint and interior....*drool* ill post a pic when its all done if i get um
Old May 8, 2002 | 12:05 AM
Sho's Avatar
Sho
btw does neone happen to know the weight of the rims? i know the iroc rims i have now weigh 40 lbs each...just wondering how much weight itll drop off.
Old May 8, 2002 | 02:01 AM
KillerCavi's Avatar
I don't know but I do know I am thinking the same sept I want 9.5 in the rear to be sure and they are cheaper .
SO I AM LISTENING!!
John D.
Old May 8, 2002 | 02:13 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Iroc rims weighing 40lbs each? Hmm, are you talking with the tire? I know the last one I bought (nasty run-in with a curb) didnt have a tire on it, and I could pick it up with two fingers. Probably weighed 10lbs at the most, I dont know exactly how much, but it seemed pretty light.
I'm thinking the Z06's will probably weigh just a tad more, since the are a little bigger. Not for sure.
Old May 8, 2002 | 10:21 AM
Sho's Avatar
Sho
last time i took off my wheels(due to a blowout....cursed tires) i had them weigh them and they weighed more then 30 lbs...i i dont know if its just my rims or what...ne info on this would help
Old May 8, 2002 | 04:47 PM
Tom84L69's Avatar
Car: 84 Z28
that weight has to be with tires mounted, no way a bare 16" weighs 40 lbs. The Z06 rims are lighter than the regular C5 wheels though I have no numbers to share. I didn't know there were two different widths for the 18 inch rim. The front wheels on C5s are 17" and the rears are 18". Therefore, all 18 inch Z06 rims should be the same width unless an aftermarket company makes a different width.
Old May 8, 2002 | 05:09 PM
Sho's Avatar
Sho
there are 3 different sizes, the first is the 17"x 9.5"(might just be 9" i dont remember) the 18"x9.5"(9"?) and the 18"x 10.5"
Old May 8, 2002 | 06:05 PM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
It seems to me that you want to put 18X10.5 all around? I don't think you can do that, expecially in the front due to clearance problems. I know a couple of people on this board have the ZR1's that are 17X11 in the rear and they have to use special spacers. the same will go for the Z06 rims. As for the Z06 rims being light hell yea they are light. What is the point of having a heavy A$$ rim on a sick handeling car? well anyway if my computer is working tomorrow I will post a link to where they sell spacers for those rims. I spoke with the guy who owns the co. and he did not recommend anything wider then the 9.5. i kept asking him about the 17X11 zr1 rims (same backspacing as the z06) and he had 2 different offsets a high and a low he totaly confused the $hit out of me. I will post the link tomorrow. The guy is reall quick to get back to you.
Old May 8, 2002 | 10:33 PM
Sho's Avatar
Sho
no im just trying to get hte 18"x10.5" on the rear and the 17"x9.5" on the front for space reasons...and if that wont work itll just have to be the 18"x9.5"...and yeah i checked the site for the rims there 9.5" not 9"
Old May 9, 2002 | 07:35 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Here give this guy an email and let him know what you want to do. he also sells the spacers you need so the rims fit like they should. See if you can understand what the high and low offset is? If there is anything else let me know.
http://www.skulte.com/adapters.html
hope that helps. I think i got the link form somewhere on this board.
Old May 9, 2002 | 10:32 AM
Sho's Avatar
Sho
thanks twiztid!!! thats exactly what i needed! the 2.25" spacers for my front 17"s and ther 2" spacers for the 18"s will be perfect and it wont rub!! woot! thanks again for the info and one more thanks to twiztid.
Old May 9, 2002 | 11:01 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Sho,
No problem. I am trying to piece some of my interior and have gotten nothing but help fromt he people here at least I can help a little. You may also want to check out preformancewheeloutlet.com I think that is the name. They have really good prices on rims. One of the cheaper sites I have seen Z06 rims. Or go to Corvetteforum.com and check in the forum under C5 parts for sale or wanted. I always see Z06 rims in there for really cheap some even come with tires. Corvetteforum.com also has a mall where you can search for parts you want they have a bunch of preformance site inks that give discounts to corvetteforum members. Worth checking out. Well worth it.
$1,195 for a setof 4 chrome z06 rims
http://store.yahoo.com/corvetteforum/corofhous5.html
check out this example of how low the rim and tire combo is on the for sale section
http://forums.corvetteforum.com/zerothread?id=295442
Well worth checkingout every day or every other day.
Old May 9, 2002 | 04:35 PM
Sho's Avatar
Sho
performacewheeloutlet.com is where i was gettin um from unless there are some cheaper in the boards u listed
Old May 10, 2002 | 07:24 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
Well the one link above has a set of 4 for $1,195. that is about $80 you save if you were to get them from preformancewheeloutlet. I think they are the place that give you $100 if you order a set of 4 right? Even if you get them from there you still ahve to pay for shipping and you could use that $80 towards shipping depending on where you live. You should really check out the for sale section every once in a while. they allways have excelent deals. Also you may want to check ls1.com classified section. I dont see a lot of zo6 rims on there but they are there.
Old May 10, 2002 | 10:17 AM
Sho's Avatar
Sho
ls1.com....hmmm...didnt even think about that...ill give that a try tonight. the $80 i would save on the tires might not be worth it depending on the shape of the tires compared to new ones....and also im looking for the polished silver rims if i can find polished silver lugs...hehehe im not a very big fan of chrome z-o6s, or the price hehehehe....but if i cant find the polished silver lugs to go with the polished rims...i guess ill just have to go with chrome...thanks again for all the help and info twiztid
Old Jul 25, 2004 | 02:21 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
hey
i just got my z06's the other day which have a +53 offset. I was going to see what they looked like but realized they didnt even mount on my car thats how big the offset is. So spacers ? 2 inch all around or what?
im gunna use a 275/35/18 tire in the front like kand.
and a 295/35/18 tire in the rear, i like the stance it gives kand. lol sorry to use your tire combo but it makes other people life easier thanks man!
but back to spacers? what should work perfect. i also want to drop my car down as far as i can.
their 18's 10.5 in rear 9.5's in front, thanks for any help
also i have the option to roll my fender lip. should i? if so just the rear or what?
sean
Old Jul 25, 2004 | 04:35 PM
Car: 2002 SS
Engine: Ls1
Sinister Z
Members Camaros
Mar 13, 2008 06:46 PM
Sinister Z
Apr 6, 2005 01:02 PM
92 zzz28
Brakes
Aug 21, 2004 09:26 PM
Barry85Iroc
South Central Region
Apr 26, 2004 03:25 PM
89BlackFBird
Theoretical and Street Racing
Mar 31, 2002 10:50 PM
