High brake light doesn't work
Old Aug 9, 2002 | 01:28 AM
Makai's Avatar
I replaced all the bulbs, and checked the fuse.
Any advice would be great!
Thanx
Old Aug 9, 2002 | 01:32 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
hey i have the same problem i did that 3rd brake light mod and made to where it would glow CAMARO with a bowtie by it, i did all of that then pushed my pedal and t didnt come on...checked all bulbs and fuse also..
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Which one do you have? The inspoiler type, the kind at the top of the hatch? I have the in spoiler type, and there are some connections where the hatch closes that i cleaned up, then it started working... I'm pretty sure that's how it's getting it's power...
Old Aug 9, 2002 | 01:34 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
mine is the 1 with the light on the outside of the hatch...only done in 86
Old Aug 9, 2002 | 01:37 AM
Makai's Avatar
3rd brake light
The brake light is on the hatch outside window
Did I mention that I changed the bulbs + fuses?
Old Aug 9, 2002 | 01:45 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
For the '86 check to see if when you push the brake does the light inside the DEFROSTER switch on the dash light up. If it does go to the hatch and check to make sure the connectors into the rear window defogger are pushed in. It should be the connectors on either side near the top of the rear window hatch. They come out sometimes from lifting the hatch. If they come out the rear brake light will not light up.
Also I too put a black bowtie emblem on my 3rd light so that when I hit the brake it lights up. Real sweet.
Old Aug 9, 2002 | 01:50 AM
Makai's Avatar
Hey, thanx, I can't wait till tomorrw to try it!
Too bad I got a pontiac.......no bowtie
pontiac doesn't have cool logos like chevy does.
got the car cheap what'ya want?
Old Aug 9, 2002 | 02:07 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
yea im gonna go try what you suggested too...
"Too bad I got a pontiac.......no bowtie
got the car cheap what'ya want? "
hey its an fbody and it was cheap doesnt sound like a bad thing to me
Old Aug 9, 2002 | 01:49 PM
castrolSi's Avatar
Mine did this too. If you can wait until Monday, I will give you a
step by step photo lesson on how to make it work again. Took me
about 2 hours of testing and looking for problems, but you can
probably do it in about 5 minutes, knowing where the problem lies.
Old Aug 9, 2002 | 04:22 PM
Makai's Avatar
Dude! That would be awesome, sure i can wait...send info to Makai2200@aol.com
it's an 86 with high brake light on hatch
Thanx, Marie
Old Aug 9, 2002 | 05:39 PM
Dana'86_305's Avatar
why not remove it
hey Marie,
Why not just remove it? I did and it was the best thing I've done to the exterior besides getting it repainted. IMO the high-mount light looks like crap, see if you can pick up a spoiler with it integreated into it. I have the IROC spoiler myself, so why not get one from another T/A? Makes a much cleaner look for the car I think.
Old Aug 9, 2002 | 07:39 PM
Makai's Avatar
Re: why not remove it
Originally posted by Dana'86_305
hey Marie,
That is something to ponder. If I sell the car, would it be worth more if it was on?
Can you send me a pic of your car without it so i can get an idea of what the after marks would be?
Thanx, Marie
Old Aug 9, 2002 | 11:59 PM
Yeah I'll borrow a friend's digital camera to take some pics for you. If your hatch glass was originally drilled for louvers like mine was, then you're already aware of the 4 circular holes that take those black plastic plugs, basically when you remove the brake light, you just buy two more plugs to fill in the holes, barely noticeable in my opinion.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
