headlight kit for trans am?
Old Sep 25, 2002 | 09:01 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I was curious if anybody knows anything about a headlight kit for thirdgen birds? I've seen the kits made for newer vettes and t/a's that eliminate the flip up headlights and look pretty good. Does anyone know if something like this is available for thirdgens?
Old Sep 25, 2002 | 09:12 AM
roadog115's Avatar
Car: 1992 Camaro Z28
Engine: L98 350 ci.
Transmission: 700-R4
Yeah I have seen a couple of people on this board with them on their firebird. I'm not for sure if there is a kit for it though. Do a search and I'm sure you'll find some more info and pictures.
Old Sep 25, 2002 | 09:50 AM
devianb's Avatar
Sorry, there is no kit. The ones on this board that have them were custom fabricated.
Old Sep 25, 2002 | 10:26 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
thanks for the help. does anyone that has a custom fabricated headlight kit have any pics or general instructions to get me started?
Old Sep 25, 2002 | 11:07 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
https://www.thirdgen.org/techbb2/sho...ght+conversion
Old Sep 25, 2002 | 11:58 AM
forsete's Avatar
I'm working on a conversion right now... It will be a couple of weeks/month before I finish it though. I still haven't figured out what to do about the 'glass'.
Obviously it needs to follow along the curves and lines of the car in order for this to look good, which means going to a pro and shelling out the $$$.
I've pretty much come to the decision to not use these on my car though. I'd much rather do what Redraif did to her bird and then weld the lids to the hood,
fill in the seams/cracks, etc (or maybe buy a Camaro hood?)
Old Sep 25, 2002 | 01:17 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I have made a page on my site about the headlight conversion I did. I did not get all the pics I should have, but so much of this is based on what lights you chose to replace you headlights. So check out my site and you can see how I converted mine!
http://www.cardomain.com/member_page...191601&page=12
Old Sep 25, 2002 | 01:47 PM
forsete's Avatar
oh, I've been to your site more times than I can count
It's very inspirational! Between your car and scauffiels’ I’m all set. Now all I need is the time and money to do everything…
Old Sep 25, 2002 | 01:48 PM
LT1guy's Avatar
Car: 1987 Trans Am
One of the fiberglass palces...maybe Unlimited, can't remember...has a stock type flat hood without the cutouts. Its a pin on, though.
Old Sep 25, 2002 | 02:05 PM
forsete's Avatar
I wouldn't mind a pin-on (or I guess locks are the way to go) I'll have to check that out. Thanks for the tip!
Old Sep 25, 2002 | 03:46 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Would a camaro hood fit on our cars? I know about the lights, but if they were gone, would they then fit?
Old Sep 25, 2002 | 04:04 PM
scauffiel's Avatar
Amen brother.
S.
Old Sep 25, 2002 | 05:02 PM
redraif's Avatar
The contours are wrong. Plus I think the noses are a touch different in length. Not realy sure though. Best bet is to play in a junk yard. Take the hoods off a camaro and bird and swap them. Get a few buddies together.
Old Sep 25, 2002 | 08:11 PM
88Bravo's Avatar
The birds are also wider aren't they. I was wondering. There goes that thought. TY Red
Old Sep 26, 2002 | 03:21 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
thanks for the help. I like the conversion on redraif's car better than the sunfire light conversion. Personally, I like the look of the flipups, but the flipups are becoming a pain. The brushes in the motors keep going bad and it's hard to find good junk yard parts. Plus the new motors from GM are 219.00 each. I'm thinking of doing something similar to redraif. That way I still have the flipup look but don't have to worry with them. BTW, redraif, how's the visibility at night? Is it as good as it was stock? Thanks.
Old Sep 26, 2002 | 03:41 PM
LT1guy's Avatar
Car: 1987 Trans Am
Shannon probably won't be able to reply before she leaves work, so I'll go ahead...
The headlights are FAR brighter than stock; I would say they are comparable to 4th gen, maybe a little better. She has wired in a relay to make all four lights come on when the brights are on, too, and that really lights up the road. They aren't so bright as to attract unwanted attention (police), but they are plenty bright.
Old Sep 26, 2002 | 04:36 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
thanks, i was curious as to how bright it would be, but if it's better than stock, then i know i can use the driving lights if i can't find anything else. I think I'm going to try to find some small headlights to use and try and similar conversion to the one on the firebird. If the headlight thing doesn't work, i guess I'll just go with the driving lights.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Catcher55
Aug 15, 2015 07:08 PM
dhonda200
Aug 11, 2015 11:50 PM
