baer brakes........
Old Nov 17, 2002 | 08:40 PM
Kandied91z's Avatar
baer brakes........
anyone have pictures of thirdgens with baer brakes or aftermarket brake kits on them.... ?
anyone here have one of those kits?
Old Nov 17, 2002 | 09:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I seen some a while back, but for get the guy that had them. I'll try a search real quick, also try the brake board too.
Old Nov 17, 2002 | 09:56 PM
Car: 99 Formula
Axle/Gears: 342
Here's a pic, they're Superman's on this board.
Old Nov 17, 2002 | 10:08 PM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
here is a pic of Tom Keilers car with bears
Old Nov 17, 2002 | 10:27 PM
FLYNLOW92rs's Avatar
Here are a picture of them, NOT on the car..........
Look on the thread " Let's See everyone's winter prohects"..........It's where i got the pic and the member that posted it is installing them over the winter...........
Old Nov 17, 2002 | 10:32 PM
Kandied91z's Avatar
it doesn't work..........
thanks for the pics guys.......i'd like to get the 13" setup for the front with the polished calipers. but i want to do some looking into it first.
anyone else!
Old Nov 17, 2002 | 10:46 PM
devianb's Avatar
I want to get a better front brake kit, but 1000! Ouch, I'm sure they are worth their cost in stopping ability.
Old Nov 17, 2002 | 11:03 PM
bollox's Avatar
Those are mine that FLYNLOW posted.
This is a good pic of the new baer's with the old brakes side by side.
This the best pic I have of them on the car with the wheel on, although it's in the air.
Old Nov 18, 2002 | 12:17 AM
89firechicken's Avatar
words of advice
the baer brakes are nothing more than the 1le brake with a name on it when i went to sema i talked to alot of guys about brakesadn i'd have to say the brake man is one of the best and if you dont think so call them because they all know their $hit. this is their link www.thebrakeman.com also global west has a 6 piston wilwood kit from the spindal out for our cars they told me the cost is around 2k but before you decide six piston is better call the brake man so they can explain why it's not.
Old Nov 18, 2002 | 12:18 AM
Kandied91z's Avatar
what kit is that..........what did it run you and do you have to make any modifications for them to fit???
thanks for all the help!
Old Nov 18, 2002 | 12:47 AM
if you are talking about the global west kit its a six piston kit they machine a new hub and modify a spindal to fit it on. so it includes the caliper, spindal, rotor, hat, pads, and even lines i think. now i cant remember i the brake man has a kit for us so you might want to make sure on that one. i havent got a kit yet but on my bird i'm getting the wilwood because of the looks and it wont be driven daily. but on my camino i'm putting the brake mans kit on for better reliability and strength
Old Nov 18, 2002 | 01:43 AM
Kandied91z's Avatar
well, i don't personally know about baer's street dependability. but as far as 1-le models go their brakes are nothing short of what some braided lines and some good pads will do on the stock setup.
1-le brakes do not impress me in the least, the are "nicer" than the stock setup; but for the same amount of money i would gladly take my chances with something like a baer or wilwood kit.
thank you for the suggestions though, i'll definately have to check that website out!
Old Nov 18, 2002 | 01:48 PM
LT1guy's Avatar
Car: 1987 Trans Am
Scauffiel has them:
http://www.transamtemple.com
Old Nov 18, 2002 | 03:26 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I love my Baer brakes. Yes the inital cost is alot I agree but they are well worth it in the long run. $1100.00 really aint bad when you look at the total investment that you put into your car. If they stop you from hitting sombody in the a$$ one day they pay for themselves right there. Overall I think if you have a nice car that you care about like Kandied does, the brakes are one of the best invesments you can make on your car.
Old Nov 18, 2002 | 04:23 PM
Kandied91z's Avatar
13 will not fit on my stock z28 rims correct?
do most of you have the 12" kit? any real difference between the two?
Old Nov 18, 2002 | 07:32 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
I'm running the 13 inch track system, about the only real advantage would be greater leverage for braking. Your in luck though, the 13 inch track system will fit behind 91-92 Z-28 wheels. Tose are the only year 16 inch Z wheels they fit behind. There is a guy name Paul Huryk I think that has the 13 inch Baers behind his 91-92 Z wheels.
Old Nov 18, 2002 | 10:44 PM
Kandied91z's Avatar
do you have a pic!!!
is there any real performance gain, what else is different besides the visual of a 13" rotor???
thanks for the help guys!!
wow that's alot of exclamation.........
Old Nov 19, 2002 | 07:28 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
The 13 inch rotor acts as a bigger heatsink. With the bigger rotors the caliper is clamping further away from the center of the spindle. This creates a better leverage advantage over the smaller rotors. Heres a pic of Pauls wheels/brakes
Old Nov 19, 2002 | 07:33 PM
Kandied91z's Avatar
those look like they have plenty of clearance.........why do so many think they won't fit??
Old Nov 20, 2002 | 02:22 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I like the Baer setup but the only thing I dont like is the price on new rotors. I e-mailed Thunder Racing and I was told that the price came in at:
Replacement rotors will run $270(Sport), $290(Track) and the pads will be $109 for either system.
That price is for 1 rotor. Can anyone get them cheaper than this or is this the standard price?
Also, are the 1LE brakes 1 or 2 piston?
Regards
Robert
Old Nov 20, 2002 | 02:33 PM
Redbird87's Avatar
Engine: 355
The 1le fronts are two piston PBR calipers which work great if you buy quality pads. Pads make or break the system.
Old Nov 20, 2002 | 02:49 PM
scrawnywhiteguy's Avatar
Even if they didn't stop a helluva lot better (which they do) It'd almost be worth it to buy 'em cause big brakes look sweet filling up your wheels like that.
Tim
Old Nov 20, 2002 | 05:37 PM
Kandied91z's Avatar
that price must be for the 2 peice rotors?
don't know.............all i know is they want 1600 for the front kit i want and 300 for the matching rotors in the rear.
so much for being close to the 1-LE, even though this is with two peice rotors that are cross drilled/ slotted/ zinc washed and the hats are anodized in your choice color or black for cheaper and polished caliper.
Old Nov 20, 2002 | 06:01 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I don't know if that is for the 1 or 2 piece rotors, they never stated. I also e-mailed Baer a while back ragarding prices of the rotors and I got ne reply.
Old Nov 20, 2002 | 06:36 PM
Kandied91z's Avatar
well since the single peice rotor is under 300 for two i wouldn't take anything less than the 2 peice if they are that much!
price sure adds up, i would hate to see a 6 piston alcon set with all these upgrades.
they should put a sign up stating for serious racers only or those with very deep pockets.
Old Nov 20, 2002 | 06:54 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Where did you get that price from? That is getting slightly more reasonable.
How much are 1LE rotors?
Old Nov 20, 2002 | 07:11 PM
WS - 666's Avatar
Ummm you can get 14", 6-piston Alcon systems from BAER...they are not a joke...
Old Nov 21, 2002 | 01:05 AM
Kandied91z's Avatar
you can get alot larger than that......i've only seen 15" though on suv's. who was joking...?
RMK that price was from anywhere.....
anyone have polished calipers or color anodized hat?
Old Nov 21, 2002 | 12:19 PM
LILRED383's Avatar
Somebody posted a while ago that the Baer brakes will not fit with 17" Torque Thrust II's. Does anybody know if that's true?
Ed1LE
Sep 30, 2018 09:14 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
84 TA NV
Sep 6, 2015 08:02 PM
Todd91SS
Aftermarket Product Review
Nov 22, 2001 07:04 PM
