Undercoating removal
Old Feb 7, 2003 | 10:20 PM
BadBowTie's Avatar
Does anyone know of an effective way to remove undercoating from under a car?
The jacka$$ I bought my Impala from found it necessary to have Zeibart undercoat the car even though in 52,000 miles it has never seen snow or salt and is only driven in the rain when it absolutely has to be.
I would like to do this with out having to disassemble the entire underside of the car.
Old Feb 7, 2003 | 10:37 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
yes very easy
take some varsol, and a cloth, and set aside many hours
Old Feb 8, 2003 | 12:05 AM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
try paint stripper and paint thinner... mix it together and let it sit for a while....dont inhale too many fumes...you might go to sleep for a little while...lol
Old Feb 8, 2003 | 02:03 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
A propane torch with a flame spreader tip & a 2" putty knife works well w/o having the chemical/rag mess. Much free time still required though.
Out of curiousity, may I ask why you want the undercoating off ?
Old Feb 8, 2003 | 02:06 AM
RPM WOT L 98's Avatar
Whoa!!!!
Carb Cleaner!! If it's relatively new it comes off with just a wipe, if it's old, you'll have to rub it a little bit but it works.
Old Feb 8, 2003 | 09:42 AM
BadBowTie's Avatar
It just isn't needed on a car that sits in the garage throughout the winter and any other time the weather isn't ideal... I want to avoid scraping, sanding, blasting, or any other process that is going to mar the underside of the car.
Old Mar 3, 2003 | 09:52 AM
camaro6spd's Avatar
r u kidding me? that is a 96 impala and there is a ton of undercoating on it and you are worried about nicks? it is the underside of the car, it already has 52,000 or more miles on it , a heat gun might work with a scraper, then apply Por-15, if you want the car to last, just leave it there.....
Old Mar 3, 2003 | 09:55 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i agree, leave it on there. i would rather have it protected even if it sits in the garage.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
HP52TA
Feb 3, 2018 10:51 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
