Firebird datona hood install - wow
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I got around to installing my datona hood, again.
I got it used from a guy who gave up installing it as well. I'm pretty sure ASCD made it: http://www.hotrodssuperstore.com/82tranorfirh.html
Anyway. First time around it wouldn't work at all. I redrilled a few of the bolt holes, and got it so it lines up and closes great. Only problem is its a little high in a few spots, and this cannot be corrected it seems.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
...Hinge mod. I had to move the holes a little. like 1/4 just to get the adjustment final.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
..ANd finally the inside. Kinda heavy construction. The front part with teh latch and spring is not bad at all. The hinge mounts are simply steel stock riveted in.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Like 20lbs. I didnt have a scale around so I didn't weigh it. If it comes off again, I'll try.
It weigs prolly half of the steel one.
-- Joe
-- Joe
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you know, those steal hoods are like 100lbs. so, your probably looking at a 45-50lbs hood.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
This may sound strange to you but you can lower the sides of that hood some (your 2'nd pic ) by loosening the hood hinges from the car and by moving them slightlly forward or back then tighten them to the hood,, it worked for mine. I just can't remember which way moves it up or down. Drop me a line if you have anymore questions..
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
