question about cleaning the engine
Old Apr 18, 2004 | 01:18 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
my engine is getting a bit dirty. what would some good products be to clean it up good? thanks for any help.
Corey
Old Apr 18, 2004 | 01:49 PM
racindaelky78's Avatar
Car: 1978 El Camino
Engine: 3??
Transmission: th350junk
just a degreaser is all you need and hot water works the best, i always leave my engine running when i do it or i put a bag over the carb and distributer when im realllly cleaning it.
Old Apr 18, 2004 | 02:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Use carb cleaner (spray can type)... powerful $hit, and it doesnt leave the engine all greasy because it evaporates away real quick.
Old Apr 18, 2004 | 03:43 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
cd-2 engine detail kit retails for about 8 bucks at autozone, and it works really great.
Old Apr 19, 2004 | 12:23 PM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
I have an LG4 What do I need to cover up to clean up my engine Becides the carb. and dist.?
Old Apr 19, 2004 | 04:54 PM
Air_Adam's Avatar
I'd cover the exhaust manifolds too, unless you are cleaning them.
If you cover them up first, then you avoid all the smoking afterward from stuff burning off.
Old Apr 21, 2004 | 06:23 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
You wouldn't want to cover the alternator, or any other accessories?
Old Apr 21, 2004 | 06:59 PM
Air_Adam's Avatar
Ok yea, covering the alternator would be a good idea if you use greasy stuff like engine cleaner. Don't really need to cover the others, like PS and stuff.
I still think carb cleaner would be the best way to go. It cleans grease and oil and gas off an engine like you wouldn't beleive, and (unless you use ALOT in one spot) you wont have to wipe anything up, it'll be dried off an a minute or two.
Old Apr 22, 2004 | 02:14 AM
Kandied91z's Avatar
depending on how bad it is a mixed solution of simple green and water works well along with old fashioned elbow work and a toothbrush if needed for certain areas.
Old Apr 22, 2004 | 09:19 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
i did this. My engine was nasty. I went to waqlmart got me 2 cans of $0.79 degreeser cans. SPrayed the entire engine bay down after i covered the battery and alternator, and then used the pressure washer to wash it all of an hour later. It said 15 minutes but the 1 hour worked quite a bit more.
One thing though, i was told this before and stuck to it, try to stay away from the rubber hoses, some degreasers are safe on paint so make sure you get one of them. Try to go crazy with the stuff, two cans is plenty enough for everything you need.
ummm..... once you've sprayed itr down let it sit for 30 minutes and get your good ole tooth brush and scrub the plenum and pretty much everyting down. Gets a nicer effect. Then try your best to get as much pressure as possible as it washes more dirt away. Try to get all the leaves out of there, they cause rot, i used my leaf blower before i got everything wet to get the leaves and loose dirt outta there. It'll look very nice for ya.
Shane
Old Apr 22, 2004 | 10:08 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I made some custome tips (duct tape and peices from the household vaccume) for a shopvac that I use for leaves.
After I washed my motor, I just waxed the painted stuff, and that made a huge differance. Now I just have to paint my valvecovers, and i'm set.
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
