underbody cleaning
Old Apr 22, 2004 | 12:52 PM
sephiroth99's Avatar
Car: 86 z28
Transmission: t-5 original
underbody cleaning
hi i just wanted to ask what would be good to clean the underside of my car it has some thick black grease. any suggestions would be great thanks
Old Apr 22, 2004 | 01:29 PM
CaysE's Avatar
Pressure washer.
Old Apr 22, 2004 | 01:30 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
If there is grease, there is no rust!
So why removing it?
Old Apr 22, 2004 | 04:43 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Grease? How'd you cover the bottom with grease? Sure its not mud?
Old Apr 22, 2004 | 05:18 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Things like leaking transmissions and leaking rear main seals and even leaking steering boxes can lead to a very greasy undercariage.
Old Apr 22, 2004 | 05:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
id leave it covered in grease or oil. Least it aint rusting.
Id welcome a control oil leak that covered the bottom of my car. But control is the key. Thought several time of dumping my old oil into a pump up sprayer n have at the under carriage.
Old Apr 22, 2004 | 05:30 PM
AmorgetRS's Avatar
I personally to clean off the bottom of my car (total repaint, inlcuding underbody) used simple green, straight up in the spray bottle and sprayed the underside, then used a plastic scraper to just start scraping it all off. I also used a blow torch for some of it, and wire brushes... and I am still not done. It takes forever... but for a show car it is worth it...
Old Apr 22, 2004 | 05:41 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
I would go ahead and clean it with a pressure washer and a degreaser additive.
Don't worry about rust, unless you live in the rust belt.
Old Apr 22, 2004 | 06:42 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
degreaser, I used purple power. Rinsed and painted black.
Old Apr 22, 2004 | 06:49 PM
AmorgetRS's Avatar
How much effort was required after the purple power? Might need to get me some of that!
Old Apr 22, 2004 | 06:55 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Basically I took a scotch brite pad and purple power, generic version of Castrol Super Clean, applied and rubbed in circles, When the pad got clogged with gunk I rinsed in very hot water to "degunk"it and continued. I was more or less removing the old undercoating and dirt/junk when I did it. It did take a while but I think it was worth it. I still have the a arms to do, I plan on doing them when I do my LS1 Brake swap next month.
Old Apr 22, 2004 | 07:07 PM
CaysE's Avatar
Wow... that trans almost looks anodized! Nice job.
Old Apr 22, 2004 | 07:15 PM
AmorgetRS's Avatar
Its powerdercoated, IIRC
Old Apr 22, 2004 | 07:20 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Yup it is.
Old Apr 22, 2004 | 07:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If your gonna go that far you'll need a lift. But it does look nice if you can. i just don't see it happening with jack stands.
At the local dollar store we have a stuff called mean green. Its the super cleaner of them all. Works wonders in a rug cleaner too. greasy 10 year old boots prints were removed. Stuff is a dollar of course.
Cleans tire like a dream if you got a car with white walls.
Old Apr 22, 2004 | 09:42 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Good stuff
get ahold of a wire brush, scraper and a case of brakeclean. Scrape brush spray.
Old Apr 23, 2004 | 02:29 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Yeah I agree with the brake cleaner or carb cleaner...get a big can of Berryman's Carb Cleaner..that stuff is awsome.
Old Apr 23, 2004 | 09:18 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Pressure washer, why didn't I think of that, I have one too.
That just make my underbody cleaning project much easier, I plan on cleaning the whole thing and giving it a coat of Por-15.
Old Apr 23, 2004 | 09:29 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Good tip, Ill try that in the carpet cleaner next time.
Old Apr 23, 2004 | 02:58 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Try using some liquid dawn dish soap. That stuff cuts grease like mad and you can get a bottle for like 80 cents.
Old Apr 23, 2004 | 03:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the undercarrage of my car was amazing when i bought it..
it was a 1 owner vert that spent the past several years stored in a garage...... the undercarrage was SPOTLESS. no rust. no oil leaks... nothing... completely clean.
currently the only mess under there is what the PS pump started doing.... but the car is still clean..
Old Apr 23, 2004 | 04:09 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
any cleaner will work good. after cleaning i used rubber undercoat with ford grey over it.
Old Apr 23, 2004 | 04:24 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Yeah, B12 Chemtool tears it up! You KNOW the stuff is strong when it makes you dizzy OUTSIDE! NEVER use it inside or you're just asking to pass out and wake up minus a grip of braincells
Old Apr 23, 2004 | 08:22 PM
Peter82Z28's Avatar
Car: Z28 / 1982
Engine: 305 (LG4) Stock
Transmission: TH350
Originally posted by SLP IROC-Z
[/B]
Cool picture to see the subframe connector!
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
armybyrd
Oct 24, 2015 06:59 AM
TheExaminer
Sep 28, 2015 02:28 PM
