Z28 wheels look horrid
Old Sep 17, 2000 | 10:11 PM
CG's Avatar
CG
i have 92 z wheels and the shiny parts are all like crazed or cracked, is it the clear coat or the alumnum? or are the wheels even clearcoated? any ideas on this?? and also the center caps, anyone know a price for new or decent ones? do i even want to know, because i am sure theyre expensive.
Old Sep 18, 2000 | 12:40 AM
Topgun's Avatar
The only place i have seen the center caps for Z28's is Yearone. And try $28.99 Each! and I'll go without center caps thanx!
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's
New Pioneer Sub
New Jensen 4-Channel Amp
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Sep 18, 2000 | 01:10 AM
Mike 25th's Avatar
Sounds like the clear coat is messed up. I have the same wheels and they don't shine like they used to. I looks like they are clear coated to me. I've been looking into replacing them for a long time, but like you said, you can buy really nice aftermarket wheels for the same price.
I should get paid for saying this, but try www.aaarims.com - they sell factory replacements in stock, chrome, polished, red, white and black - centercaps too! They even give you up to $700 dollars for your in trade as long as they aren't curbed or dinged. It's a good place for 4th gens too if you wanted those. Even the front wheels off of a C5 Corvette will fit whith spacers
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
Check out the T-Ram at my website:
http://www.mylecdekmat.com/mike.htm
Old Oct 1, 2002 | 03:28 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ttt
Old Oct 2, 2002 | 09:59 PM
360Iroc's Avatar
its the clearcoat....
www.keystone-auto.com
Old Oct 2, 2002 | 10:02 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Yeah, its the clear. Strip it and I would recommend polishing them. Try a search, someone had a REALLY AWESOME looking 91-92 Z28 rim polished.
Old Oct 3, 2002 | 02:26 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I with Metalli on this one. There is no need to junk the ones you have and get new ones, just strip the clearcoat and do some polishing. It takes some work, but its well worth it. And it only costs about $40 to do it yourself, at least that is what it cost me. Do a search, polishing has been brought up numerous times. Trust me, you will appreciate your wheels alot more.
Old Oct 3, 2002 | 02:59 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Try a search huh...
First you rag on me, then you steal my gimmick.
I guess if you can look at yourself in the mirror......
Old Oct 3, 2002 | 06:39 AM
Nazzz28's Avatar
Car: 91 z28
Transmission: 700 R4
CG - I just finished polishing a set of the same rims earlier this
summer. Here are some pictures of them before and after, along
with the center caps. If you want the process I used do a search
on "polish" and look for my username, I know I wrote out a
detailed procedure in one of my posts. By the way in my opinion
they look even better on the car. I will be getting some new pics
as soon as I get the car back from the transmission shop.
This is what I started with. I purchased them used and the clear
was peeling and cloudy like you described. This was actually after
the clear was removed with stripper and they still look pretty bad.
Old Oct 3, 2002 | 06:40 AM
Nazzz28's Avatar
Car: 91 z28
Here is one after sanding and the first round of polishing.
Old Oct 3, 2002 | 06:43 AM
Nazzz28's Avatar
Car: 91 z28
These are after the second round of polishing and paint. I used
a self etching primer, charcoal metallic base (2 coats), and two
coats of clear. Sorry there are no pics of the wheel with the center
cap in place, but I included a pic of the center cap when it was
done.
Old Oct 3, 2002 | 06:44 AM
Nazzz28's Avatar
Car: 91 z28
Here is a closer look at the wheel spoke.
Old Oct 3, 2002 | 06:45 AM
Nazzz28's Avatar
Car: 91 z28
A closer look at the painted insert.
Nazzz28's Avatar
Car: 91 z28
Lastly the center cap.
Old Oct 3, 2002 | 06:52 AM
Nazzz28's Avatar
Car: 91 z28
Sorry for all the posts I don't know how to post multiple pics at
once. If I were you I would look into polishing the wheels you
have, and I'll be glad to answer any questions. I know I was
going to get some 17" wheels, but spent half the money on
these ones used and the supplies to complete them. I am
extremely happy with the results and find it even more gratifying
to be able to say I did the work on them myself .
Old Oct 3, 2002 | 08:26 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
You ought to take that post you referred to, and make it a tech article, so people will not come on here every other day and ask how to do this. Just an idea......by the way, how does the polish hold up?
Old Oct 3, 2002 | 08:35 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Like THAT'll stop 'em.
Old Oct 3, 2002 | 08:53 AM
Nazzz28's Avatar
Car: 91 z28
Gunny Highway - I am not to sure how the polish holds up, since I
have only driven my car about 200 miles since they were mounted.
I just got done with an engine swap, and the car is at the
transmission shop getting the final tweeks to the freshly rebuilt
tranny. I think it should hold up fairly well because the little driving
I've done was in the rain and it has sat at the shop for
a couple of weeks and they are still shining. I am pretty obsessed
with keeping them clean anyway so they sould hold up pretty well.
If I have a problem I am going to order some Wheel Wax from
www.tirerack.com and apply some of that and see how it works.
Old Oct 3, 2002 | 09:47 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Damn!!! Nothing else needs to be said do what Nazzz28 did!:rockon:
<img src=https://www.thirdgen.org/techbb2/attachment.php?s=&postid=908739>
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
