need ideas
Old May 14, 2004 | 02:55 PM
Kandied91z's Avatar
need ideas
i need ideas for fender inserts on my car. now that i have to roll my fenders and remove the plastic inserts that help keep the car clean i need to come up with something else. anyone have an efficient idea that would work well for this sort of thing?
Old May 14, 2004 | 05:05 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Make it out of fiberglass and paint it body color.
Old May 14, 2004 | 05:15 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Mold your own out of ABS with a heat gun?
Old May 15, 2004 | 03:03 AM
Kandied91z's Avatar
fiberglass isn't efficient for the idea. the plastic may work but where would i get such a piece that would be workable...i might as well try reforming the stock piece i suppose.
Old May 15, 2004 | 02:32 PM
Scott_92RS's Avatar
Car: 1992 RS
ABS comes in many thicknesses, and can be cut to any shape you want, then heated while being formed to retain the curves you want. Maybe use some poster board as a template, then cut the same piece out of ABS and use a heat gun to make the bends.
Old May 15, 2004 | 02:57 PM
Kandied91z's Avatar
where would i begin to look for the abs plastic?
Old May 15, 2004 | 03:19 PM
FLYNLOW92rs's Avatar
I would just use the ABS plastic to cover any areas where dirt and other stuff are prone to getting stuck, basically just make it so everything will wash right back down, out of the wheel well....
Old May 15, 2004 | 04:50 PM
Kandied91z's Avatar
yeah that's what i'm trying to do. i can't keep the stock gm piece because the tire pushes up on it when the car drops down...need something that tucks up a little more and i don't want to leave it bare. not only does it look terrible but then it will get really dirty on the road.
Old May 15, 2004 | 06:13 PM
Scott_92RS's Avatar
Car: 1992 RS
Just google for ABS Plastic and I'm sure you'll find a few dealers, check the yellow pages too.
Is there no way to modify the stock piece in such a way that will move it a little higher up, out of the wheel's way?
Old May 15, 2004 | 06:24 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Try www.mcmaster.com They have everything.
scroll down to raw materials and you'll find plastics. They have it all.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
