shaving
Old Aug 9, 2004 | 06:15 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
shaving
whats the best way to shave an antenna hole without welding anything?
Old Aug 9, 2004 | 08:41 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
The only way to properly do it, would have to be welding a peice of metal to fill the hole. Any other way would be sorta half assed, if you ask me.
Old Aug 9, 2004 | 11:11 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Well not all people know how to weld, have access to a welder, or want to dish out the $ for someone else to do the job
92rs I didnt have acess to a welder either and wanted to do the body work myself. What I did was use fiberglass filler and matting. I put the matting on the bottom of the hole and then just used filler. Welding would be the best way no doubt, but im working with what I got.
Old Aug 9, 2004 | 11:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I dont think a shop would charge too much to just weld a plate there. It's what, the size of a half dollar at most? Try calling around. Whats the worst that could happen? You're not going to like the rates?
Old Aug 10, 2004 | 06:38 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Could just pop a hole plug in it. It wouldn't be "shaved" but will be very un noticeable if you paint it to make the car. I had one onthe back of my car for 3 years before I realized it was hole plug. It just seamed part of the car but not till a few weeks ago I realized it would just pop out.
I was gonna switch mine around. Put the plug in the front and the antenna in the back.
I assume the hole in my left rear was for a CB that was removed. So I bet a CB shop will have an assortment of nice looking hole plugs.
Old Aug 10, 2004 | 06:42 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its kind of odd how long I had that sucker on my car and just never thought about it. It looked normal or part of the car.
Old Aug 10, 2004 | 08:51 AM
I dont know how to weld either, I'm just telling him if he wants to do it the right way... he will need metal in there. Thats just fact dude. No need to roll your eyes
Old Aug 10, 2004 | 09:35 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Yeah of course welding is the best way. I just dont think its half assed if you do it some other way. I worked with what I had and still made it look nice. It should last a while till I get a good paintjob, Then I will get it welded. Im just a broke college student
Old Aug 10, 2004 | 10:02 AM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
just bondo the damn thing and wen it cracks put some more on there !
I myself just have the hole there, could car eless about filling it.
Old Aug 10, 2004 | 10:56 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
apply 3 layers of fiberglass mat to the inside of the fender over the hole with plenty of resin, then bondo over the outside,keep sanding untill smooth, primer and paint.
Old Aug 10, 2004 | 11:16 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
3M makes a panel bonding adhesive that is damn good. They use this stuff in body shops to attach door skins,quarter panels and what not. If you don't want to weld this is the next best thing in my opion.
http://products3.3m.com/catalog/us/e...eme_us_aad_3_0
Old Aug 10, 2004 | 08:46 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
hey
I just shaved my antenna... i did it like i filled all the other holes for my highrise spoiler... The way i did it was cut a little square out of a peice of sheet metal that would go behind the hole.. then i just tack welded it in place all the way around.. primered it then filled it with evercoat.. held up great
Old Aug 10, 2004 | 08:49 PM
Car: 2002 SS
Engine: Ls1
IM only 16 with barely any practice with the stuff but i'm getting better
after
Old Aug 10, 2004 | 10:25 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
While I know your intent wasn't to be an *** (and I'm not trying to attack what you said). There are many ways to fill a hole that don't require metal fusion, all just as good as welding as far as durability goes (as it is just an antenna hole after all....).
The only true half-assed method would be to put masking tape over the hole than layer build primer over it untill you can sand the primer to blend (the underlying tape) with the panel.
Sounds funny I know but, it has been done and... I am not that creative to make something like that up (truth is stranger than fiction so is said).
Granted, this was not on a car but, it was a metal 'patch' none-the-less.
Old Aug 11, 2004 | 12:12 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
ok well i went ahead and shaved it, i jb welded a rectangular piece of sheet metal under the hole, the cut out a round piece the size of the hole and jb welded that in place and went over it with some 3m finishing putty and sanded it smooth. it turned out pretty good....thanks for the input guys
Old Aug 11, 2004 | 01:20 PM
FLYNLOW92rs's Avatar
I don't care how you do it, but as long as that antenna isn't on your car, I couldn't care less how it was taken off........
For the love of ***, as long as the thing is gone, it's going to look better, even if use a Mcgyver type method to do it.......
Frozer!!!
Jan 19, 2024 04:55 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
madsv1000
Aug 20, 2015 06:45 AM
