New gauges are in!!!!
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Well in totally finished finally with doin the gauge swap. the biggest thing that held me up from finishing was my led light bulds took 2 weeks to get here but it is worth the wait.
anyway i used Autometer ultra-lite gauges and blue led bulbs the bulbs alone almost cost as much as my speedometer. bulbs were $151 ouch but good.
anyway im postin 2 pics right now in the day time since i just took them and its only 3:45 ill post a pic later tonight to show with the lights on.
tell me what u think? this is one thing off the big list of things to do.:lala:
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
How well did the three-gage A-pillar pod fit? Are any of the gages in it mechanical? I have a mechanical boost gage in my TT IROC using an autometer 2-hole pod, and was not happy with the fit (the pod fit over the factory A-pillar trim, and didn't leave much room for the boost sense line- the gauge sticks out approx 1/4"). Was your 3-hole pod made by autometer as well?
Kenton
Kenton
Car: 05' GTO
Engine: 6.0L
Transmission: A4
well im back with a night time pic.
89JYturbo - the bottem gauge is a vacume gauge and if your boost gauge is set up the same way my vaucume gauge is. where u have that hard line goin in the back the you'll have to drill/trim a hole in the original piller for it to sit flush. also my gauge pod was made by Autometer.
85maroz28 & Abubaca - the bezel is from Corvan's Classic. i didnt buy it directly from here, i bought it off of a member on here whichdecided not to use it or the wiring harness that Corvan's Classic sells.
the gauges are abit brighter in person i just dont have a very good digi camera that takes night pics. but this is how they look. im not so happy with how bright the speedo is becuz of how autometer mounts the plate with the numbers on it becuz if it had the screws that hold it on to the outside it should be just as bright as the rest. i guess with how they have all the electrical stuff on the inside thats the only way they could mount the plate.
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Re: New gauges are in!!!!
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Originally posted by DigitalMonarch0
I wasn't aware that autometer was now making an A-Piller pod that houses 3 gauges?
Car: 05' GTO
Engine: 6.0L
Transmission: A4
its probably just the pic becuz before i put these even closeto the car i made sure they werent, i hate if even one is just off a bit. ill check tomarrow
well 91bird305 if i started to list make a list i would probably get pretty long if i went into detail. but a small list consists of
droppin in my big block (496 when i get done) , th400 trans, 12 bolt , 3 1/2'' alumin driveshaft, pretty close to all new if not NOS body parts, 80-81 z28 fender vents (sittin in the closet), ascd big block hood, car repainted black with a candy apple blue stripe. lowered 1-2'', finish off the suspention, either 17 or 18'' rims, baer disk brake kit front and rear, and either all new interior parts or atleast fix all the little things in it. thats a shortened list.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hehe
thats the day i got the motor. now its totally stripped, well 2 days after i got it , i stripped it and its on a engine stand not a tire
thats the day i got the motor. now its totally stripped, well 2 days after i got it , i stripped it and its on a engine stand not a tire Member
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Hey tim. If you know where you can get wire holders for them valve covers, let me know. I have the same exact valve covers on my 90 454.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Guages looks great ! .. that big block looks sweet as hell too
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey thanx guys
and chevy496 im probably not goin to use these valve covers , there what my friend was using at the time. more then likly i wont be using them but ill keep a look out for the wire looms for ya.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
man, those gauges are sharp, sweet deal
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thanx guys, im kinda happy im done with them but not sincei dont drive the car that much anymore right now. maybe i can finally start on restoring the body this winter since i wont be driving it much at all.
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Guys...
I may be totally dense, but I can't find a listing for an A-Piller that houses three gauges for an 82-92 camaro.
Can anyone enlighten me?
