got a new special buffer
Old Nov 23, 2004 | 07:04 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
so i was crusing the autobody store and i found the perfect addition to my tool collection. i have a ton of overspray in my engine bay and i needed a way to buf the area after wet sanding. so i found this deal figured why not. i can;t wait to try it. and i bet this would make wheel polishing a snap. my billet boyds will need polishing sooner or latter and this should be the perfect size for those jobs.
figured i would share since it is the first time i have ever seen one like this. anyone ever try one?
jeff
http://autobodystore.net/Merchant2/m...tegory_Code=T2
Old Nov 23, 2004 | 07:07 PM
JeffW's Avatar
Engine: 305 tpi LB9
heres my bay kinda hard to see but if you look near the hood bumper thingy you can se the over spray, and i think i can buff the lip on the hood and fenders also. i'll post up some results when i try it this week since i have some time off it will be the best time to play around.
Edited nope you can see how bad it looks time for alot of detailing.
jeff
Old Nov 24, 2004 | 03:08 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah ive seen that before on the matco and snapon trucks. i always bought the buffing and polishin pads from that kit to use with my right angle diegrinder. i think i might pic up that buffer to see if its much different
Old Nov 24, 2004 | 04:27 PM
JeffW's Avatar
Engine: 305 tpi LB9
i think the rpm is like 2500 i would have to check i'll let you know how it works i should be doing detail work this weekend.
jeff
Old Nov 24, 2004 | 09:22 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if its that low then i might get it for buffing/polishing alumin. becuz i think my die grinder goes way past 2500 rpms.
Old Nov 25, 2004 | 09:07 AM
JeffW's Avatar
Engine: 305 tpi LB9
yes i think a die grinder is close to 4000. i have a right angle die grinder what a handy tool. havent tried buffing alum with it yet. i seen this and though of rims for it nice size to get in to all the spots.
jeff
Old Nov 25, 2004 | 09:14 AM
nolanr0413's Avatar
Car: Trans am
hey jeff have you tried buffing with it yet .
Old Nov 25, 2004 | 10:25 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
ur much better off using a clay bar to remove the over spray. wet sanding and buffing is a lot more pain then u need to go through to take care of it.
Old Nov 25, 2004 | 10:32 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
I would agree with SLP. Even though its a small buffer youre still gonna have problems in the tight areas. Also i can almost guarantee youre gonna catch the pad on a screw or edge or something and ruin your brand new pad. Use a product like 3M swirl mark remover or something like that. You put a little dab on a cloth and by hand remove the overspray. Then just use a hand glaze to make it shine perfect. Followed by a wax.
Old Nov 25, 2004 | 08:16 PM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
DUDE!!!!
i have the same exact buffer..
it's the best thing ever!
i used it on my wheels.. all the tight spaces!
the taillights..
it's got endless uses!!!
It is perfect!
Old Nov 25, 2004 | 10:54 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
whatd it run ya?
Old Nov 26, 2004 | 12:46 AM
Kandied91z's Avatar
better use an air regulator...overspray is better then burnt paint.
Old Nov 26, 2004 | 07:57 AM
JeffW's Avatar
Engine: 305 tpi LB9
price you can click the link that is where i got it. less than 100
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Thaney9
Oct 24, 2015 07:26 PM
Bradsaundry
Oct 7, 2015 04:35 PM
tattmann
Sep 27, 2015 05:20 PM
