Should I mold the front bumper and front fender into one
Old Dec 10, 2004 | 11:49 AM
91NiteRida''s Avatar
Car: 1991 Camaro
I was looking at some posts and I was wondering what everyone thinks about me having the body shop make the front clip look like its one piece...My camaro has to have the whole front end repainted anyways so i might as well do it now...What does everyone think??Yes,No maybe so ..If you need pics of what im talking about,ill try and post them...But its pretty self-explanatory...
Old Dec 10, 2004 | 01:03 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
i like the idea. but if u did the front bumper i think u would have to do the back bumper to so it would look right.
Old Dec 10, 2004 | 01:09 PM
CrazyHawaiian's Avatar
Car: too many ...
Thats what I'm gonna be doing with my car. I'm getting the front end, sideskirts, and rear bumper molded. But watch out, if they dont know what they are doing the paint will crack over time because of stress. I have seen cars with flush GFX and molded front ends that lasted on the street (no cracking) but it was alot of work to re-inforce everything and prevent flex. The other guys I know that didnt re-inforce anything ended up getting cracks / seams.
Old Dec 10, 2004 | 01:11 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I think it would be a really cool feature...but...I'm not sure if it would be very succesful in the long run...it would more then likely crack..
Old Dec 10, 2004 | 02:40 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
scauffiel tried to make his Firebird seamless, but I think he ran into the problem mentioned above with cracking. He hasn't posted here in a while though.
Old Dec 10, 2004 | 02:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
are you talking about plastic cracking or just the paint having problems? dont they have special coating to make the paint somewhat flexible for plastics?
i wouldnt thing the front ground effects would flex much when molded to the top front fascia. Unless you scrape bottom on dips and stuff, but other than that, should be better to be one piece. would look nice.
Old Dec 10, 2004 | 04:31 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
When I first joined the forum, some discussion was taking place on how to do this...
I don't think molding the fascia to ground effects would be an issue, with the right products.
HOWEVER, you really won't get away with bonding metal (the fenders) to urethane (the covers)!
We're talking two different substrates, with two different heating and cooling properties... and a lot of stress between parts.
Have you ever seen a third generation "Vette that has not been restored with new products?? There is a line of demarkation that shows up where the actual fender meets the upper body...GM put a seam and a bonding agent there that didn't show until a few years down the road...some even cracked. (and THOSE WERE compatible substrates!!)
Old Dec 10, 2004 | 07:08 PM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
I could never see doing this mod.... I have been rear ended by a first year driver, a first day driver and a van full of Guatemalans with no license... needless to say I am glad that a bumper cover can be changed without any serious issues
Old Dec 10, 2004 | 08:29 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
good point. what if for some reason you had to remove something? I say it would be a cool idea for a show car or a car that does not get driven alot. But for a daily driver I dont think it would be worth it.
Old Dec 10, 2004 | 08:57 PM
megaracerx's Avatar
they would stil be seprate peices, i would assume. they would only be using body filler/fiberglass to smooth it...so if it does need to be replaced, it wouldnt be a huge difference the stock form.
Old Dec 10, 2004 | 10:37 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I'm talking about whatever he was filling the seams with cracking, and most likely the paint as well but I am not sure... I never tried it.
Old Dec 10, 2004 | 10:43 PM
devianb's Avatar
Those urathane bumpers have quite a bit of flex in them, going to be a real problem if you go seamless and drive your car regularly on city roads or drive it in high heat and cold. Its going to crack, just a matter of when.
Unless it was a car I just used for show purposes I wouldnt do it at all.
Old Dec 12, 2004 | 05:38 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
dont do it.
Old Dec 12, 2004 | 05:50 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Kandied just mad a post about a flip front end..
The front end is one piece..
Thats the only way to go ...
Attached Thumbnails Should I mold the front bumper and front fender into one-glasteck-frontend.jpg
Old Dec 12, 2004 | 07:41 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Yeah, I'd do that. ^
I also asked about this when my car was in the shop. This was a place that does show trucks that get the covers of magazines and they advised me against it. If the pros say its bad, I tend to believe them.
Old Dec 12, 2004 | 11:49 PM
305RSlc's Avatar
Transmission: 700R4 that will magically turn into a 6 speed one day.
Would doing this be more feasable if fiberglass fenders were added into the mix? I think our cars, especially the camaros, would benefit greatly from molded and smoothed GFX to the bumper and fenders; I'm personally not too fond of the seams and have been pondering doing this for some time. It seems though, that the general consensus is that the metal fenders, and the stresses between the metal and polyurethane, are teh only things hindering the overall success of doing this. By adding fiberglass, or even polyurethane, fenders to the mix, couldn't this be more feasible?
Old Dec 13, 2004 | 05:57 AM
Car: too many ...
I agree that it will eventually crack, but I think it will last longer than alot of people think if its done right. I think most shops wont recommend it because its so time consuming to do it right, that it rarely justifies the cost or time. It seriously takes alot of time to do this and not end up with cracks all the time. From the shops perspective the average person isnt gonna pay that much to mod their ride, and if they did, they would probably expect it to last forever. To do it right, everything needs to come off and supports need to be fabricated from the inside to keep everything solid, help eliminate or minimize that vibration. Kinda like when the truck guys completely shave the tailgate of a truck, the guys that do it the right way build supports on the inside. I've seen guys do this to attach all different types of materials to steel bodies (fiberglass, polyurethane, etc) and had it last for years, with $6000 paintjobs no less. But yeah I would agree this is probably not a good idea for a daily driver. The more you use it, the more likely it is to crack. Thats a fact.
Old Dec 13, 2004 | 10:24 AM
Car: 1991 Camaro
well thanks to everyone that gave their .02 cents worth...Its not gonna happen thats for sure...maybe on my next project
Old Dec 14, 2004 | 05:42 PM
Charged350's Avatar
Car: 87 IROC Z28
Wont happen ever, if they were both steel then yes, one steel other plastic, nope, the only way ur gonna get that is with that complete fiberglass clip, i was gonna do that to mine since i shaved everything off, but i didnt, why, cuz it will never last...ever.
Old Dec 16, 2004 | 06:42 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Just for Fun
Old Dec 16, 2004 | 09:07 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
doesn't look all too bad, I do like the lines though
Brandon
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mikey8494
Aug 22, 2015 07:57 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
