Can't find Functional Ram Air 1 Hood
Old Jul 3, 2005 | 11:24 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
I'm trying to find a "functional" ram air 1 hood for a 92 firebird, I've tried searching the threads with no success. Yet I've noticed members with the hood so I know it exists. Also will the ram air 2 filter box work with a ram air 1 hood, if not I'll need to figure out where to get one of those also.
Old Jul 3, 2005 | 02:07 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is the thread about the RA1 hood and the Airbox from the RA2 hood.
https://www.thirdgen.org/techbb2/sho...hreadid=302108
here is another thread,
https://www.thirdgen.org/techbb2/sho...hreadid=282410
Old Jul 3, 2005 | 10:15 PM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
Thanks, that helps with the air box question. But where do I find a functional ra1 hood. Do they just no make them, and am I going to have to cut up a non functional hood.
Old Jul 4, 2005 | 07:05 AM
Zepher's Avatar
you just have to cut openings at the back of the hood.
Old Jul 5, 2005 | 03:55 PM
LT1guy's Avatar
Car: 1987 Trans Am
If you're talking about a functional RA1 hood like Redraif's
http://www.redraif.com
with an airbox, they used to be available from Suncoast Creations. Not sure if they still are though. No one else made a hood that would work with an airbox (the scoop is in the wrong place).
Old Jul 5, 2005 | 06:16 PM
Zepher's Avatar
I wouldn't call Raifs hood an RA1 since it is a little different.
The Suncoast airbox looks identical to the airbox I have that came with my second RA2 hood, which is used in the two threads I linked above with the ASCD RA1 hood, like the one I got from you.
None of them are really Ram Air though, just a glorified Cold Air intake setup.
Old Jul 7, 2005 | 12:50 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
I tried contacting suncoast creations about there hood and I haven't had any responce yet (No surprise since I just did it today).
So the only way to get a true ram air is to get the RA2 hood. I like the RA2 hood, but I think it looks better on the 4th gen. I want something less noticable. The RA2 Hood is to bulky for my taste. But I also wanted the advantage of Ram Air. I guess I'll just have to wait for a response from suncoast for now.
Old Jul 7, 2005 | 02:07 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Just FYI, True "Ram Air" is a myth. All of them just provide really good cold air.
Old Jul 8, 2005 | 12:40 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
Thanks for the info. I checked out the thread and learned a lot. It should be cleaned up and put into a sticky or faq (or maybe it is already and I just didn't see it). I'll probably get the hood anyways. I like the way it looks. Thanks for the Info everyone.
Thread for the ram air myth for those who are curious
https://www.thirdgen.org/techbb2/sho...t=true+ram+air
Old Oct 8, 2005 | 05:04 PM
TR Fowler's Avatar
Car: 83 Camaro Z28
Engine: 8161 Supercharged SBC
Transmission: TH-350 w/3000 Stall
Axle/Gears: 3:73 to 1
Have ASCD hood
I have ASCD hood for $400. It's functional.
Old Oct 8, 2005 | 05:15 PM
LT1guy's Avatar
Car: 1987 Trans Am
Re: Have ASCD hood
We were talking about functional as in being made to accept a sealed aribox, not just open in the front.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
