Do I primer these wheels?
Old Sep 19, 2005 | 05:54 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
Hey im 15 and im restoring my thirdgen. I have some 15x7 firebird wheels off my 89 formula 350. They are discolored, but are pretty smooth.What I need to know is if you have to put primer over aluminum wheels? or do i just paint over what I have? thanks alot these are going to look sweet
Randy
Old Sep 19, 2005 | 06:04 PM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
Get a powder coating, they look nice and will last longer. Jusy my opinion, good luck and I wish I could help you on your original question. Do a search in here and you will find the answer.
Old Sep 19, 2005 | 09:38 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Primer is really only used for any metal that will rust. So, you won't have to use primer on your wheels, Aluminum doesn't
Old Sep 19, 2005 | 10:41 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Not necessarily true. Primer provides better adhesion for a paint therefore it makes sense to use.
Check it:
Other TGO members adventures in wheel paint.
My adventures with wheel paint.
I hope this is helpful.
Old Sep 20, 2005 | 03:48 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
FYI; No thirdgen formy came stock with 15" wheels.
Old Sep 20, 2005 | 05:29 PM
Engine: 5.7
[QUOTE]Originally posted by Cadillac
[B]Not necessarily true. Primer provides better adhesion for a paint therefore it makes sense to use.
If it were me, I would just scuff the aluminum up with a scuff pad. That is where you really get your product to stick...not with primer. The main purpose for primer is to protect against rust...BUT it will also help with adhesion. But scuffing up the aluminum should be fine.
Old Sep 20, 2005 | 05:54 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Ever seen a broken wheel after it was powder-coated. Most of the time, the baking process will weaken the alum.
Old Sep 20, 2005 | 07:29 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Id like to see pictures and Proof it was because of the powdercoating.
90% of the FACTORY rims are powdercoated.
I do aluminum 4wheeler frame, etc .never seen a problem yet. I know the guy who does all fords factory rims here local.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
