Bubbled tint removal
Old Oct 3, 2005 | 08:48 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I just got an 89 IROC Sunday.
The rear window has some badly bubbled tinting on it.
It is so bad I can barely see through it.
Does anyone have any tips on how to remove it,
without lifting the Rear window defogger traces.
Thanks for any Help.
Old Oct 3, 2005 | 09:05 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
I had mine done, but it was also retinted, when i bought mine it was BAD purple and bubble, they steamed it off and retinted everything for like 250 bucks...
Old Oct 4, 2005 | 08:53 AM
Hot Shot GTA's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt/3.27 Posi
I removed mine. The tint shop would have charged me 40 bucks for them to take it off. So I thought I'd spend 10 bucks or so on supplies and try it myself.
I used a razor blade, and carefully I might add. Start in a corner and try to make sure it all comes off in one piece. If it doesn't the layer left on the glass does not come off very easily. I peeled it slowly, and as evenly as possible so it would not tear on me. Be careful on the defrost lines cause once they are cut I don't think they can be repaired.
For the glue I used some Goo Gone I think it was called, and very fine steel wool (#0000). Did that a couple times, then glass cleaner to finish it up.
There are other ways of doing it, some probably easier then mine, but it worked good for me.
Old Oct 4, 2005 | 09:47 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
a huge jug of acetone would work, what ever you do make sure you have ventalation. I recommend a small fan pulling fresh air in and bad vapors out
Old Oct 4, 2005 | 10:17 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
You don't want to get acetone on your interior plastic...
Stuff called "tint-off" available at Wal-Mart is what I used (it is Diluted ammonia). Used a razor blade to start one corner then sprayed this stuff on and the tint comes right off. Once the tint film was off, used some more of the spray to take all the glue off. Didn't hurt the plastic or defroster lines. No smell after either.
Old Oct 4, 2005 | 11:05 AM
yea, it tends to eat up the plastic lol.. careful with that stuff. To many people who didnt know what they were doing or didnt read instruction labels would be the cause of cheap products that dont work as well. We use to have good paint stripper, until someone caused themself a chemical burn and sued the company. We use to have superglue that could hold almost anything at high tensile strengths until some... *holds breath* glued their hands together or eye shut. All these things have been taken away and replaced by cheaper products that dont work as well as they should. All because people are.... *holds breath again*
Old Oct 4, 2005 | 02:13 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Thanks Everyone for your replies.
I've got a lot of suggestions to think about.
Old Oct 5, 2005 | 08:12 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Well, mine came off quite easy, the person I got it from apparently put it on himself so I took it off myself, just started to peel from one corner to the other nothing else needed. You should see how easy it will come off before spending money on it.
Engine: 388 Carb
Axle/Gears: 4.10
I apologize for the double post, I didnt even realize it.
Old Oct 5, 2005 | 10:50 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
iv taken some tint off before, use a heat gun . Put heat on the outside of the window and peel. use thinner to get the adhesive off. If you start to peel off the defrost grid make sure to curse at your car they like that
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Fronzizzle
Feb 9, 2017 09:31 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stroopwafel
Sep 11, 2015 06:38 AM
