Who Owns This Car
Old Feb 19, 2006 | 04:43 PM
zrated57's Avatar
Who Owns This Car
I saw this car on ebay a while ago and I was wondering if anyone knew how I could contact this person? I don't know if I'm posting this is the correct spot. I don't know if there is a way to seach completed items on ebay from months ago. But if anyone knows who owns this car, please post. I want to get exact wheel and tire specs from them. THANKS
Old Feb 25, 2006 | 03:57 PM
Kandied91z's Avatar
the wheels do not even fit the car right and you would like to duplicate it?
check out any of the mainstream wheel companies such as weld, centerline, etc. and you should have no problem finding a similar style wheel that will bolt up with zero complications.
just do a bit of research..
Old Feb 25, 2006 | 06:37 PM
zrated57's Avatar
I don't understand what you mean by "the wheels do not even fit the car right" ? I know the wheels are Weld Racing Draglites. 15x8 rear and 15x3.5 front, but I need to know backspacing and offset as well as tire size, that's why I was asking. It looks as if they fit great!!
Old Feb 25, 2006 | 06:57 PM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
Maybe he meant they don't look good with the car.
Old Feb 25, 2006 | 07:11 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i just got a set for free that i took from a foxbody mustang thats being parted out. i really like the way they look and i agree with zrated. i had to order new lugnuts though before i can put them on.
Old Feb 25, 2006 | 08:03 PM
zrated57's Avatar
That's cool MaNiAk86. I think they look good too. I think it gives the car a drag car look. I just wanna make sure I am getting the correct sizes & measurements because I want it to appear identical to the one in the picture. And I know lots of tire and wheels sizes will fit and can definitely change the look dramastically.
Old Feb 26, 2006 | 10:32 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
15x8's will need a 4.5" backspacing. it appears that the guy in the pic above is using a 275/60/15 tire out back and one of the 165/r15 series tires up front.
Old Feb 26, 2006 | 10:39 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Some of us prefer the drag look as opposed to the 18" bling bling! Sidewalls Rule!!
Old Feb 27, 2006 | 12:20 AM
stitchop's Avatar
Car: 91 firebird
I like the Draglites, it is not the wheel for my car, but I would rather have them than 18" chrome. I think 15" or 16" wheels with a 50 or 60 series look better.
Old Feb 27, 2006 | 08:39 PM
zrated57's Avatar
You say the rear has a 4.5 backspacing, what about the front. Do you know the offset or bs on the front wheels? What is recommended, because I doubt they will be the same as the front. What if I went with 15x6 or 15x5's in the front, what bs & offset woud be ideal? thanks
Old Feb 27, 2006 | 08:46 PM
CYARS92's Avatar
I've used 15 x 5's with 3.5" bs. No problems at all & with that offset it still looks like a 3.5" rim. It also gives you a little more confidence that you won't roll a tire off the rim while taking corners at any great speed!
Old Feb 27, 2006 | 08:54 PM
zrated57's Avatar
you know your stuff, i always need info, thanks
Old Feb 28, 2006 | 03:37 AM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
Re: Who Owns This Car
That picture looks fuggin hot. Please post pics if you get this done!
Old Feb 28, 2006 | 09:30 AM
zrated57's Avatar
Absolutely!! Orioles rock!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Linson
Aug 21, 2015 02:12 PM
gwade12
Aug 8, 2015 08:17 AM
