Burnt Rubber
Old Apr 26, 2006 | 10:06 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
Burnt Rubber
How can i get the burnt rubber pieces off my paint? Im tired of looking at the black rubber on my pearl white paint...
Old Apr 26, 2006 | 10:28 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
any all-purpose cleaner or degreaser should take it off, but dont use your wash mit to rub it off because the rubber wilkl stick in the wash mit. you can use a terry towel or any old towel you have layin around. To gaurd against it next time you can buy this stuff from jegs or summit that you spray on your rear quarters before you go to the track and then the rubber will just wipe right off. I can't remeber the name of it, but im sure somebody else will.
Old Apr 27, 2006 | 02:30 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
Geddex burnout guard is the name of the stuff.
http://http://store.summitracing.com...5&autoview=sku
Old Apr 27, 2006 | 06:41 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
wow that stuff looks really cool thanks for the tip waldershrek.
Old Apr 27, 2006 | 08:12 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
yah thanks
Old Apr 28, 2006 | 10:46 AM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I also have seen old school racers use vasiline on the 1/4'S the rubber sticks to the vasiline then you just wipe it off.
Old Apr 28, 2006 | 12:27 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
this will sound crazy, but WD40 gets it off... then you just have to wash it afterwards
Old Apr 28, 2006 | 02:44 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
water and soap
Old May 1, 2006 | 07:09 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
the wd40 worked great
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Gordonr1973
Sep 29, 2015 11:59 AM
Bigold4x4
Sep 28, 2015 05:21 PM
gta_knight
Sep 23, 2015 04:59 PM
gta892000
Sep 16, 2015 12:37 AM
