new hood (self made)
Old Jun 10, 2006 | 12:36 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
new hood (self made) UPDATED!!!!!!
here's my new hood i made for an 84 z28.
The old hood was dented and VERY rusty.
the new hoood was a stock flat hood, i cut a hole in it so the aircleaner has more room. Topped it off with a plastic hoodscoop.
There will be a new 383ci engine it.
Costed me lots of sanding and i used minor bondo to make it smooth.
had to cut off the trims that were on the scoop, it had tape on the bottom to stick it on a hood.
but i wanted to make it smooth.
the 2nd pic doesnt do it justice at all, (car will be painted...someday).
[IMG]www.thirdgen.org/techboard/attachment.php?attachmentid=120049&stc=1&d=1149960874[/IMG]
Attached Thumbnails new hood (self made)-autonieuwekapindemaak.jpg   new hood (self made)-autonieuwekap.jpg
Old Jun 10, 2006 | 12:42 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
That looks cool. It would be really cool if you could have it coming through the hood and have the "shaker" effect like on the mustangs.
Good job
Old Jun 10, 2006 | 01:20 PM
BADNBLK's Avatar
COTM Editor
I don't like it. Looks cheap - which I'm sure it was. Joe dirt - says it all.
Old Jun 10, 2006 | 01:29 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
i think it looks pretty good.. its on smoothly on there right? like no seam in between the scoop and the hood?
Old Jun 10, 2006 | 04:35 PM
PREDATOR's Avatar
I think it looks cheap too.....ur poor car .
Old Jun 10, 2006 | 06:26 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
to each his own i guess
Old Jun 10, 2006 | 07:02 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I just have yet to see one of those glue on or rivit on things that look good once done...
Old Jun 10, 2006 | 07:44 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I think it looks pretty good.... Better than most that I've seen on these cars.
Good job! Paint the hood next, don't wait to paint the entire car.
Old Jun 10, 2006 | 08:26 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
So you said that you wanted to wanted to smooth it. Did you mean the scoop to the hood, seamless?
Just a word of warning... With a plastic hood scoop on a metal hood there is a extremely good chance you will have issues with the seam cracking. There is so much pull on the hood from the wind when you are driving that that plastic scoop is going to flex. That flex will continually cause cracking at the mounting point b/w the 2 surfaces.
I mounted the ta fender scoops in the ta fenders seamlessly and i and having some cracking issues! This is after locking the vents in place and then fusing them to the fender with a 3m product designed for bonding unlike surfaces.
So if you plan to do this be prepared!
Old Jun 10, 2006 | 09:20 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
excellent craftsmanship, but i'm not a big fan of that particular hoodscoop.
A+ on the effort! keep up the good work.
Old Jun 11, 2006 | 01:43 AM
Car: z-28 x2
Yes, it is on smooth, upclose you wont see any lines or whatever, it looks just like its made out of one piece.
heres a pic up close, i like the scoop being not too big, just right i.m.o.
BTW: i used fiberglass-epoxy (or whatever its called in english) on the inside to make it strong, i used minor bondo on the outside to make it smooth.
Attached Thumbnails new hood (self made)-autonieuwekap2.jpg   new hood (self made)-autonieuwekap3.jpg
Old Jun 11, 2006 | 05:04 AM
91sleeperRS's Avatar
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
good job. post pics when painted
Old Jun 11, 2006 | 09:04 AM
conlinj's Avatar
I think it looks good, You did it right, looks like you took your time with it and it came out good.
Old Jun 11, 2006 | 09:18 AM
Stevo's Avatar
Car: Pair of 92 Z28s
those last pictures look alright, it doesnt look that cheap cause it looks like it was done correctly. Im not to fan of the look but as long as its not tacky/cheap looking i think its fine. You see lots of people put those scopes on hoods, but they dont actually bond them on thats why it can look cheap sometimes. Great craftsmanship though!
Old Jun 11, 2006 | 10:51 AM
tummyson's Avatar
Car: 89 IROC
Transmission: 5 Speed
Axle/Gears: 3.08 Posi
I like it, the last set of pics look good.
Old Jun 11, 2006 | 01:14 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
i dont think it looks that bad. yes there are better aftermarket hoods out there than the one you made, but that doesnt look like something i would laugh at or call ugly if i saw it driving down the road
Old Jun 11, 2006 | 01:40 PM
DanTheMan18's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I like it. Doesn't look bad at all.
Old Jun 13, 2006 | 09:57 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
remember guys, he's in the netherlands, i bet shipping of an aftermarket hood from like Ohio or some place is NOT going to be cheap. i think it turned out pretty good for the amount of $$$ involved. once painted, i think it'll look really good and probably turns heads already. and i'm definitely a fan of getting cool air to the motor. now, make a pan out of aluminum and foam to seal the carb to the hood so it ONLY ingests cold air.
Old Jun 13, 2006 | 12:09 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
good job the craftsmanship looks great the second set of pictures look alot better than the first ones.
Old Jun 13, 2006 | 12:41 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Looks like a job well done. I think the hood looks mean. Good work!
Jay
Old Jun 13, 2006 | 01:26 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
looks very good, professional even... it'll look killer once its painted
Old Jun 13, 2006 | 01:33 PM
hihighost's Avatar
Car: 1987 Camaro
Engine: Carb'd L31 Vortec 350
Axle/Gears: 4th gen torsen / 3.23
Yes, it might look a little tacky if anything only because it's not completed...But certainly not cheap. The job looks really well done and once you painted, it's going to be a wicked sweet hood.
Old Jun 13, 2006 | 07:41 PM
djphonix's Avatar
Car: 92 camaro, 88 , camaro sc , 05 phantom black GTO
Engine: 383,313,364
Transmission: 700r4, t-5 , t-56
i hope you know thats a ford hood scoop my brother has one on his restored and complety stock ford torino
Old Jun 14, 2006 | 11:06 AM
Car: z-28 x2
yeah, im aware of that
on my iroc i have a cowl induction type 4 inch, so i wanted something different on this camaro.
I also wanted some more room because of the new engine and somesort of cold air induction, so this is the scoop i picked.
i made a bit of a mess of the cowl induction scoop, so i wanted to do it right this time.
Thanks a lot for the compliments and all the honest replies.
Old Jun 16, 2006 | 10:33 AM
Car: z-28 x2
on all 4 corners it started to crack! goddamned!
all tips are welcome
Old Jun 17, 2006 | 02:18 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
Man everyone is so quick to knock it down, yet if you make it a bit longer and put a hump down the center it be identical to the big block or what ever that other hood is that everyone has....
i think it looks good, nothing extravagant or over the top, almost just small and subtle i like it and give ya props for the time involved
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
