Finally interior and engine pics!!!
Old Jul 20, 2006 | 09:32 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Check the Interior pics!!
http://www.cardomain.com/ride/223847/7
Here are some engine pics.
I still need to tuck & hide some wires.
http://www.cardomain.com/ride/223847/6
I took the pics at the last minute. Would have been better if I had pulled the car out of the garage.
Im just glad to finally get some new pics up!!
Old Jul 20, 2006 | 09:42 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
looks good....
Old Jul 20, 2006 | 02:15 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Very nice!
Old Jul 20, 2006 | 03:11 PM
t-rex_camaro's Avatar
Car: 1991 camaro rs
Transmission: auto
Axle/Gears: 2 axles and a set of gears
was that car a tbi setup or was it always carbed. looks nice like the car looks clean.
Old Jul 21, 2006 | 08:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
It went from TBI to TPI to carb!!
Old Jul 21, 2006 | 03:03 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Nice work!! Looks real good!
Old Jul 22, 2006 | 09:02 PM
Car: 1991 camaro rs
Transmission: auto
wow that must of been a pane. if u dont mind teling me a list of the parts u got to make it carbed i would be vary thankful u did. i to am thinking of puting carb on my car but its gust a 305 but im sick of the tbi and the computer mesing with my car.
Old Jul 23, 2006 | 12:26 AM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
im just finishing up my tpi to carb swap right now. should be done tomorrow. i have the same regulator and the same manifold. i got a polished performer rpm...looks the same i think.
as for t-rex, theres a great list in the techarticles on the tgo homepage (not the forums). lets see, manifold, carb, air cleaner, regulator, upper radiator hose, waterneck, throttle bracket, throttle and tv studs, carb studs, plenty of plugs and fittings, some feul line and clamps, a distributor, and thats just about it. there might be a couple little things here and there that i forgot.
Old Jul 23, 2006 | 02:40 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
Clean!
Old Jul 23, 2006 | 04:13 PM
Car: 1991 camaro rs
Transmission: auto
hey thanks ill have to go look at that page. hope to be carbed soon im sick of my tbi.
Old Jul 24, 2006 | 08:08 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, I have the performer RPM airgap. It is a great intake that flows through the whole rpm range. I would definatly suggest it to anyone needing a good intake.
Old Jul 24, 2006 | 08:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Of course you need a carb, intake, return style afpr, non-computer controlled dist. New plug wires, fuel lines, throttle bracket, carb studs, water neck. Intake gaskets, carb gaskets, maybe a dropbase air cleaner. Then just some odd and ends.
You will have to wire up the fuel pump to come on also. You will be able to get rid of most of the wiring harness.
I t would be a good time to replace the cam while the intake is off!!
You need to remember to match up all you components. Intake/carb/cam/heads/gears!!!!!
Old Jul 24, 2006 | 10:15 AM
Car: 1991 camaro rs
Transmission: auto
thanks for the info...cant wate to switch my tbi to carb.
Old Jul 24, 2006 | 10:21 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have a Speed Demon 750 vs carb for sale if you are interested. Might be a little too big if you 305 is stock.
Good luck with the swap. Remember to pick the right intake. A good dual plane should work just right.
Old Jul 24, 2006 | 10:35 AM
Car: 1991 camaro rs
Transmission: auto
i plane on puting a littil smaller carb on. probly a 650. but thanks anyways. yea i am going to be buying a intake soon.
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
