Some pics being clean
Old Oct 8, 2006 | 03:00 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Just thought I would throw some pics up of the Z all cleaned up.
Hopefully we can make it to the track one last time before things start getting taken apart again for their usual pursuit of something faster lol.
Attached Thumbnails Some pics being clean-newcamaro1.jpg   Some pics being clean-newcamaro4.jpg   Some pics being clean-camaro-cruise.jpg
Old Oct 8, 2006 | 06:47 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
looks good for the most part except for the stance , i dont like how its so raked,it would look better if it sat flat.
Old Oct 8, 2006 | 10:42 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
a smaller rake would look MUCH better...it looks like its been taken to the extreme...a slight rake would really make it look sweet
Old Oct 8, 2006 | 11:05 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
holy huge drag radials in back....what size are they?
Old Oct 8, 2006 | 11:25 PM
izcain's Avatar
Engine: 584
295/65/15 and thats why the rake is the way it is any lower and the tires rub. I have slowly been working on getting it lower in the rear.
Old Oct 8, 2006 | 11:39 PM
xpndbl3's Avatar
Car: 1984 Z28
put some air bags in the rear that will limit rear end dropping during launching.
i use 5-10 psi in the drivers and 25-35 in the passenger depending on conditions.
Old Oct 8, 2006 | 11:46 PM
izcain's Avatar
Engine: 584
Do you run the 50/50 shocks?
Old Oct 8, 2006 | 11:52 PM
xpndbl3's Avatar
Car: 1984 Z28
yes i do run the 50/50 shocks, the air bags stop the springs from compressing as much, they do lead to a bumpier ride, but it's better than having it way jack'd up
Old Oct 8, 2006 | 11:54 PM
izcain's Avatar
Engine: 584
That sounds like a good plan. What tire size are you running? I wanna transfer to a 325/50/15 with a 15X10 rim. Do you know what kinda backspacing I would be needing in order to make it a proper fitment?
Also what kinda gears are you runnin? and times?
Old Oct 9, 2006 | 12:00 AM
xpndbl3's Avatar
Car: 1984 Z28
i'm running 28x10.50 ET drags on 15x8 with 4.5bs pro stars
some people run 15x10 rims with 5.5bs on them. Some inner fender mods will be needed for the slicks to fit or in your case the drag radials. Bump stop removal and metal welded in place of it and the lower front part of the wheelwell is typically beaten inward or cut out and replaced with thin guage metal as well for more room. I also rolled my fender lip to gain room there and no more worried about them cutting into slicks anymore
Old Oct 9, 2006 | 12:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
295/65/R15 eh? Excellent, i'll have to remember that. I LOVE the raked stance you've got going on.
What width are those wheels now?
Old Oct 9, 2006 | 12:43 AM
izcain's Avatar
Engine: 584
theyre mounted on a 15X8 rim right now (theyre the most I could fit).
xpndbl3 do you happen to have any pics of the inner fender mods and things done to clear? I would appreciate it very much.
Old Oct 9, 2006 | 12:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
Excellent, thanks izcain, I have 15x8's, maybe i'll look into 295/65's next
Old Oct 9, 2006 | 12:56 AM
izcain's Avatar
Engine: 584
I believe mine have 4.5 BS. I have liked them, they have worked really well plus they are larger in diameter so it helped give a little more MPH with the same ratio. But now that I have changed I would like to go to the 325/50/15's. I dont think I have ever gotten full effect of them though it seems like I never get a good enough burnout in the box before hand, and my understanding is that they need a pretty good heatup before the passes. Oh well im going on more time to the track and this time maybe I will get them heated enough and they will stick!
Old Oct 9, 2006 | 01:04 AM
xpndbl3's Avatar
Car: 1984 Z28
i don't have pics but the mod of the drag racing board has posted them before, try searching for wheelwell mods or inner fender mods with his name stephen87iroc or whatever it is.
Old Oct 9, 2006 | 01:12 AM
izcain's Avatar
Engine: 584
Oh sweet thanks ill definitly have to search.... one of the many wintertime projects for the car.
Old Oct 9, 2006 | 12:32 PM
xpndbl3's Avatar
Car: 1984 Z28
sounds good, i'm hoping this winter to just change the oil, and put a cover over the car until next spring when I'll pull it out. Hopefully I won't get the mod bug some more and add more parts this winter.
Old Oct 9, 2006 | 12:35 PM
izcain's Avatar
Engine: 584
Aww I dont know what I would do with all the extra time and money i would have if I wasn't able to keep installing parts and changing others out lol
Magman
29
Sep 12, 2015 10:41 PM
IROCtometal
Sep 9, 2015 10:01 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
