Whats the point of a COWL HOOD?
Old Nov 26, 2006 | 11:39 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
I see them on all sorts of drag street cars, and even a few trucks... Do they do anything or are they just there for looks or what?
-Thanks
Old Nov 26, 2006 | 11:51 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
give me more room for my engine, and it should draw air from the windshield...IF its made correctly.
Old Nov 26, 2006 | 03:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you are running an induction system that sits too high to fit under the stock hood, you can gain a lot of clearance with a cowl hood, and they are made to draw air from a low pressure area that is created at the bottom of the windshield on cars. ive got one on my car and you can see it work, spray down the hood and winedshield and go for a spin, the droplets on the lower 12" or so on the windsheild will run towards the center of the car and then travel down the windshield towards the cowl opening, kinda neat
Old Nov 26, 2006 | 08:11 PM
Leroy Brown's Avatar
Car: 89 Iroc z-28
Transmission: Tci TH350
Axle/Gears: 10 bolt 3.42
Yea, looks much better than having a top of an aircleaner sticking out of your hood.
Old Nov 26, 2006 | 09:11 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Cowl hoods were the original cold air intake.
Old Nov 26, 2006 | 09:51 PM
Zyth01's Avatar
How do you keep water out of them in the rain?
Old Nov 26, 2006 | 09:57 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Normally you dont... My one friend had a 91 RS and had a 4 inch cowl hood and an open element and he drove that in the rain all the time. i cant imagine how it worked but it did...
and Z2Eight....do you have anymore pictures of your car?? Where are you near pittsburgh?...I live in Allentown but i go 2 Pitt so basically im in pittsburgh 7-8 months a year now...
Old Nov 27, 2006 | 10:23 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
PM'd Mack
Old Nov 27, 2006 | 12:06 PM
UDAMON's Avatar
Car: Mazda Protege5
they look sweet... and are fiberglass.....well some are anyways....
Old Nov 27, 2006 | 08:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i dont drive it in the rain on purpose... but the rain isnt going to be blowing straight into the engine anymore that it would be blowing up into the engine bay with a closed hood, the aircleaner may get damp, but i dont know if the engine would actually suck water
Old Nov 27, 2006 | 10:54 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
i originally got mine for blower clearance, then decided to play the all motor game at the time......looks wicked cool too
Old Nov 27, 2006 | 10:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Got mine for weight savings, they dont make stock iroc style hoods, so i went with the lowest cowl possible. looks good too.
Old Nov 27, 2006 | 10:58 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Rain isn't a problem with them.
Old Nov 27, 2006 | 11:14 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Rain really isn't a problem as stated above.A screen can be fabricated to keep out leaves and other pests but not obstruct airflow in.And the other added benefit is letting hot underhood air out.
Old Nov 27, 2006 | 11:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i got mine to look cool.
Old Nov 28, 2006 | 01:04 AM
Night rider327's Avatar
Car: 1988 Camaro
Here's mine.. http://rides.webshots.com/photo/1501...41290424xcxiuX
http://rides.webshots.com/photo/2699...41290424YrInoJ
There's 2 main points to a cowl hood..
1) so the engine can draw in cooler outside air from the base of the windsheild
2) to have room to fit your intake/carb/air cleaner setup under the hood
Old Nov 28, 2006 | 11:04 AM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
i personally dont go for the cowl look myself, but its a neccessity when you got a big engine. !!!HEY! Answer this question someone!!! What is the benefits of a jongblowed hood? Are they lightweight?
Old Nov 28, 2006 | 03:57 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Jongblowed hoods are just a rounded off cowl. Yes they are lightweight because theyre fiberglass. I would say the diff between a fiberglass Jong' and a regular fiberglass cowl is negligible. But the Jong is just plain nasty.
BOOYA
So... maybe Im a little partial.
Old Nov 29, 2006 | 05:21 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Except the nasty part. I think they look good.
Anyway, they're the same thing. Just look different.
Old Nov 29, 2006 | 05:26 PM
davez's Avatar
Car: 1991 Z28
Axle/Gears: stock 3.08
Maybe a stupid question but how does the hood open? Doesn't the end of the cowl swing into the windshield?
Old Nov 29, 2006 | 05:41 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The hood lifts up and then swivels up just like the stock one. Hard to explain, but it should open just fine. Unless you broke something...
Old Nov 29, 2006 | 10:14 PM
xpndbl3's Avatar
Car: 1984 Z28
mine is a pin on so my hood opens by 2 guys grabbing the 4 corners and then placing the entire hood on the roof of the car. much easier to work on engines that way, just if you don't have 2 people the hood isn't coming off.
Old Nov 29, 2006 | 11:37 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
For the Trans Am's with the "Power Bulge" it's on a solonoid relay. I don't know when it opens, but I have a special air cleaner assembly set up thats specifically designed for it. It's supposed to take the air from the bottom of the windshield and pull it into my carb (84 T/A). I think it's supposed to give the same effect as the dual snorkle on the Camaro's...but instead of pulling twice from behind the headlights, I only pull once from the headlights and once from the cowl. Tomorrow after work I'll take some pictures and see if I can get them posted for you.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
