any1 recommend certain stuff on plenum and valve cover?
Old Mar 4, 2007 | 12:16 PM
bigtom88transam's Avatar
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
a nyone have any recommendations on good stuff to use on chrome valve covers to get off some surface rust and to make them shine like stock.... and also to get shine back in on the plenum and runners as well as TB?
Old Mar 4, 2007 | 12:40 PM
brp88gta's Avatar
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
i took the whole intake off and took it apart and glass beeded everything then sprayed it with clear. for the valve covers, i used duplicolor aluminum engine paint and then sprayed gloss engine paint clear over it, and they are almost exactly the same color as orignally. for the plenum, i used eastwoods ti-coat high temp paint and then sprayed it with high temp satin finsh clear. the throttle body i sparyed with eastwoods alumi-blast and sprayed it with the same satin clear coat. the runners i just glass beeded and sparyed with clear like the intake. i tried very hard to find stuff that made it look orignal and stock. it takes some time to do all of this, but it is well worth it if you really want you engine to look good.
Old Mar 4, 2007 | 12:48 PM
Engine: 305 tpi
very good thanks for the info :-)
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
