Marine Fog Lights
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Marine Fog Lights
I recently replaced the foglights on my TA, i had some old lights off of my boat that had perfect lenses but the housings were destroyed. they fit perfect in the housings on my car and man what an IMPROVEMENT.... they dont have the metal deflector infront of the bulb so its like another set of highs... must suck driving towards me
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Marine Fog Lights
Use the "go advanced " button and scroll down till you see manage files. from there up load em from your comp
Car: 1989 Trans Am
Engine: 5.0 TPI
ok thanks for the instrux. now just gotta wait for the sun to do its thing ill take some when its light out too
They have driving lights at wal mart that fit perfectly too. Theyre in a box that says Blazer on it. Theyre only like 17.99. And they also dont have any reflectors in front of the lights. Theyre so bright I sometimes use them alone as my headlights and I can see just fine.
Today I got some new fog lights from trusty ole wal mart for $18. Same size/same look (except new!) for my 90 firebird (GTA style) cause my old ones look like crap (17 yrs old...meh). So Im gonna do the same thing as you did mlaskow86.
But I need some advice before I begin please....-I need to adjust the pass side as its pointing a bit in the up position.
-Could someone explain the obvious to me as how to remove my old housing and replace//adjust these?? I could just use the new lights w/the old housings or replace the whole thing.
-I actually did mess around and took a the lens/housing off from the opening in front, so its a little famiar to me so far, but....
-I do not want o break something like I usually do.
-I will prob splicing in to the existing ground & power.
-They are mounted from the top right? (thats how it looks anyway).
Thanx!
Thanx!
Car: 1989 Trans Am
Engine: 5.0 TPI
i kept the old housings and just put in the new bulbs... the foglights has the same wiring on them so i didnt have to splice anything just unplugged the old ones and plugged thenew ones in.....
