Water spots on hatch glass that will not come off?
Old Sep 9, 2007 | 07:34 PM
87_TA's Avatar
Just obtained a 94 firebird that now houses my 406,t56 from my 87 that is now totalled..(RIP) Anyways it was a Georgia car and had sat for a long time from what I can tell..
Well it has water spots all over the hatch glass that will not come of!! I have washed and washed, used steel wool, mother wheel polish being its an abrasive.. No good.. Even tried paint thinner..
Here is pic of car
Any thoughts?
Attached Thumbnails Water spots on hatch glass that will not come off?-img_2123.jpg
Old Sep 9, 2007 | 07:46 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Re: Water spots on hatch glass that will not come off?
If you have a high speed rotary buffer try some Meguiar's #4 Heavy Cut Cleaner. It is quite possible, though, that the mineral deposits in the water actually etched into the glass. In that case you're sort of screwed - polishing glass, and I mean polishing in the sense of polishing metal or paint, is nearly impossible.
Old Sep 10, 2007 | 09:06 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Zaino has some glass stuff that WILL take it off with a lil bit of rubbing. i used it on my 89 formula and the glass looks brand new. had much water spot action before hand. another friend has a 92 heritage and used my then later bought his own after how well it worked on his. and i also used it on my 86 S-10 with equally excellent results.
http://www.zainostore.com/Merchant2/merchant.mvc
http://www.zainostore.com/Merchant2/...oduct_Count=14
Old Sep 10, 2007 | 09:32 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
razor blades and windex
Old Sep 10, 2007 | 10:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
white vinegar and you'll be fine, rub it on and spots come off. if not get some rubbing compound and have at it.
Old Sep 10, 2007 | 10:35 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
I've always washed my windows using windex and "newspaper". Sounds weird but newspaper works so much better than other rags and stuff. Try it and see. My windows look perfect when done.
Old Sep 11, 2007 | 12:27 AM
Duratys's Avatar
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
Ceramic stove top cleaner and some elbowgrease.............
Old Sep 11, 2007 | 12:37 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
look in the yellow pages for automotive detailers and look for a company that sell detailing supplys, they have a product, not sure of the name but is like Water Spot Remover, its made for windows, u can use that with 0000 (super fine) steel wool, but try this first 0000 steel wool and a GOOD automotive glass cleaner (like stoner) use the steel wool as if it was a paper towel, the clean the window like normal..... BTW thats a Detailer secret LOL not anymore .............. also the news paper trick as mention above is all detailers use on normal conditions for cleaning windows, i know you used the steel wool before, if you allready did it with the good glass cleaner than just do as i mentioned first
Old Sep 11, 2007 | 01:14 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
None of you guys have hard water in your house?
I would try LimeAway first. Or the Menards brand...Lime Out....or even CLR. Test it on a spot...you should be able to watch it fizz a bit...then rinse off.
Unfortunately, my city water is just hard enough to require me to use one of the above products to keep the sinks/toilets/showers clean.
HTH...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
punkmaster98
Sep 30, 2015 11:01 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
