Pics of 15" wheels on 3'gen
Old Jan 25, 2008 | 12:13 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi
thinking of getting some 15" wheels for my bird.
http://store.summitracing.com/egnsea...5&Nao=10#rstop
Skinnies up front and some stickeys at the rear.
What offset and backspacing would I need so I can get some fat tires in at the rear and it shouldnt look to bad up front either.
please post pictureas and wheels/tire size.
thanx!
Old Jan 25, 2008 | 05:32 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Pics of 15" wheels on 3'gen
15x10 w 5.5 backspacing and 15x3.5 front. 29x 11.50 hoosier quick time pro`s and moroso 28x 4.5
Old Jan 26, 2008 | 08:20 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Any offset?
Front rims and offset/backspacing?
More pictures? looks badass ......
Summit only makes 4" wide up front, wonder If they can take the load?
/N.
Old Jan 26, 2008 | 08:33 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Mickey Thompson ET Drag wheels 15x8 out back with 4.5" backspacing, 15x3.5" up front, 1.75" backspacing, 275/60/15 Mickey Thompson ET Street Radial tires out back, 26x7.5" Mickey Thompson Sportsman front runners. i think there's only 3 of us on this board with these wheels, and you just got two of them back to back, lol!
Old Jan 26, 2008 | 10:41 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
15x8 rear with 5.5 backspacing i believe.. i have a 4th gen rear end. i also run a 5/16" spacer. 15x4 up front
Old Jan 26, 2008 | 11:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Looks badass!
I think I would like 10" at the rear, will they hit my fenders? or do I need to fix my susp @ rear?
/N.
Old Jan 26, 2008 | 12:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
15x8 is skinny with the 26x10.50 tire. you can fit the wider 11.50" tire on it. i've done it before. it would work well with a 10 inch rim too tho.
Old Jan 26, 2008 | 04:26 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
How is it to drive on the street with only 4" front rims?
Old Jan 26, 2008 | 05:51 PM
Originally Posted by gta324
Any offset?
/N.
ah, the front drag wheels usually have very little offset, I believe mine had either zero and 20mm avaliable, I went with the 20 to give a little caliper clearence. the back rims did not have offset choices from what I remember. I think the backspace on the front was 1.5
Old Jan 26, 2008 | 06:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Obviously vehicles that run skinnies usually are more drag orientated. So no quick turns, sudden braking, etc and they're fine. I run manual steering so it definitely helps in that regard.
Old Jan 26, 2008 | 07:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah i got a radial front tire, a 165/80/15 but it could use stiffer sidewall, ie more ply. Its rated to i believe 1200lbs each tire. I'm probly closer to 1000lbs each front.
The drive isnt bad, i keep the shocks setup somewhat stiffer up front and it drives fine. still have the big sway bar on. you can tell your on skinnies, and cant take turns that hard, but other than that, it feels fine
Old Jan 27, 2008 | 12:36 AM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Ill bite...
Thinking about lowering the front just a little..
Old Jan 27, 2008 | 10:04 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Stock 15's:
Standard sizing, OEM stuff. I think the tires were 225, 50, R15.
Old Jan 27, 2008 | 10:22 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Stock 15's on mine, click the link in my sig to see better pictures. 15x7, and I lowered mine 1-1.5".
Old Jan 27, 2008 | 01:56 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Heres my car with 15 inch cragar SS's.
Old Jan 27, 2008 | 05:27 PM
Cadillac's Avatar
So basically, you've got to get high profile tires right?
60 or 70 series heights?
Old Jan 27, 2008 | 05:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
to keep a stock sized 25.7 inch outside diameter, smaller rims need bigger sidewalls
Old Jan 29, 2008 | 08:56 AM
chikn305's Avatar
15x3.5 ft 15x10 with 5.5 bs
Old Jan 31, 2008 | 07:28 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
chikn305: 5.5" BS at the rear ?
What about the front?
any offset?
Old Jan 31, 2008 | 08:35 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
8x15 255/60-15 and 7x15 235/60-15 Cragar Superspoke. don't know the backspacing.
nebu.
Old Feb 3, 2008 | 02:15 PM
501dave's Avatar
Here's mine Just put them on friday.
Old Feb 3, 2008 | 02:18 PM
501dave's Avatar
275,60,15 M&H street radials & 215,70,15 fronts
Old Feb 3, 2008 | 02:24 PM
501dave's Avatar
In action.
Old Feb 5, 2008 | 06:20 PM
chikn305's Avatar
any offset?
I think the front prostars are only available in one offset and Im not sure what it is.
Old Jan 5, 2011 | 03:53 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Finally
Will go for 15x10 Weld draglites 26" 275/50R15 MT ET Street in the rear.
Fronts will be 15x7
Not sure about the BS in front 3,5 or 4,5? any pictures?
Tires will be 215/70R15 or 235/60R15.
Old Jan 5, 2011 | 05:33 AM
mw66nova's Avatar
Engine: 7.0L
the factory 15x7 wheels have "zero" offset, which means the mounting flange is exactly in the middle of the wheel, thus having 3.5" of backspacing. i would use that for the backspacing on your 15x7's. the 15x10's with a 5.5" backspacing will fit easiest without too many inner fender mods though i will suggest rolling the fenders. this back spacing will put the sidewall bulge even with the fender lip. i'm rnning a 6.5" backspacing and the tire is completely under the car now, but you have to cut the bump stop area and beat the ever living crap out of the inner fender to get it to clear.
Old Jan 5, 2011 | 11:00 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Will use 4'th gen rear so 15x10 with 7,5" BS is on the way.
My stock 8" GTA rims in front have 4,75 BS...I think..
takin 15x7" with 3,5" BS will make them slightly further out that my stock ones, correct?
Will think about it... its easier to put a spacer on if I want to move the wheel further out than the other way around
Old Jan 5, 2011 | 11:20 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
You sure about that? I thought wheel width (x7) was the distance between where the bead sits. So bead to bead is 7", overall width, face to face, is closer to 8". Backspacing is from mounting surface to face, so on a 7" wheel 0 offset has a bs of ~4".
Old Jan 5, 2011 | 12:26 PM
mw66nova's Avatar
Engine: 7.0L
well, they measure 3.5" bs last i checked...
1992rs/ss
Jan 31, 2025 05:10 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
