'87 Formula Wheel clear coat HELP.
Old Apr 29, 2009 | 08:57 PM
gpdscott's Avatar
Car: 2 - 1987 Yellow Formula's
Engine: 5.0l tpi , 5.0l 4 bbl
Transmission: 5 speed , 4 speed auto
Axle/Gears: 3.08 , 3.43
Hello, I am wondering if anyone can help me. I took my stock wheels out of my shed, they have been there for 1 1/2 year's. and I noticed the clear coat is turned a little yellow, and looks like it may be starting to lift from the wheel's, or stained. Do anyone know of a way to fix it without getting the wheels refinished?
Thank's forhand..
Glen.
Old Apr 30, 2009 | 11:19 AM
1Aauto's Avatar
Former Sponsor
Re: '87 Formula Wheel clear coat HELP.
Thank's forhand..
Glen.
Glen, That clear coat's a pain on any aluminum wheel.I just posted this on another thread.It shows you how to refinish an aluminum wheel youself.
http://www.flashoffroad.com/features...on_wheels.html
Old Apr 30, 2009 | 12:31 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Aggreed with 1atony order a polishing kit and strip the clear coat off. If you don't want to take it all the way to a polished look, you can strip the clear coat and re clear them or have them sprayed by someone.
Aircraft aluminium striper works great on the wheels, autozone carries it.
I've had good luck with the dupli color spray paints for wheels. Just let it cure a while before you drive it or the brake dust will eat into the paint.
I would bet that the clear is yellowed all the way through. I just ordered a set of formula wheels that I will re-finish when i get them. Although the main reason I ordered them is to have some roller wheels/tires while I fix a few spots on the TA wheels I have on it that I didn't like the way it turned out. They also had some brake dust on them when I stored the car a couple years ago as well as the random things that got on them and well I want them back to a mirror finish.
Old Apr 30, 2009 | 02:18 PM
gpdscott's Avatar
Thank's guy's...
Will to Aircraft Striper hurt the paint in the fins on the wheel's?
Old Apr 30, 2009 | 02:45 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
It will strip all paint so if you get it on it it will remove it. I usually buy the gallon stuff not the spray can and brush it on.
I would strip the entire wheel and polish. Then tape it off where you don't want paint and repaint it. I've used wheel paint in the spay cans and it works well and last 4-5 years before it dulls.
This is the kit I've used for polishing.
http://www.eastwoodco.com/shopping/p...iProductID=953
Old Apr 30, 2009 | 02:59 PM
1Aauto's Avatar
Former Sponsor
I have Weld aluminum wheels on my Mustang I might try that corn startch trick.
Old Apr 30, 2009 | 03:02 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
or instead of chemical striper you can sand off the clear coat.
Old Apr 30, 2009 | 05:55 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
por 15 makes an awsome wheel refinishing kit the coating needs to be sprayed on to look good.IT will never yellow and looks awsome.http://www.por15.com/GLISTEN-PC/productinfo/GPCGG/ hope the link works.I still suck with computers.
Old Apr 30, 2009 | 08:07 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Have you tried the por 15? it looks interesting. I may have to give that a try. I like the polished wheels but clear coated is easier to maintain.
Frozer!!!
Jan 19, 2024 04:55 PM
diana227vegas
Jul 8, 2016 12:27 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
