My engine compartment restoration
Old May 21, 2009 | 02:41 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Got real tired of the total black out look in my camaro so I decided to pull the motor out and start on the restoration. My engine compartment was originally white so I wanted to go back to it for a long time. after I completed the painting, I then decided to do the underside of the car to. Here are some pics of it. After all the crap was stripped off the floors , they are finally prepped and ready for painting.
the beginning
in progress
Old May 21, 2009 | 02:42 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Re: My engine compartment restoration
Finished
The floors after many hours of cleaning
finally the rear end it done also. About 4 hours of wheeling on this one. I have some touch up to do but this new product called KBS is great. Its like POR-15 but comes in colors.
Old May 21, 2009 | 02:43 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
I hope to have the floors done by this coming weekend.
Old May 21, 2009 | 02:56 PM
91camaro372's Avatar
Car: 91 Camaro RS
Engine: 3.1L v6
Axle/Gears: 2.73(for now) posi disc from 95 Z28
Hey man the engine compartment/rest of the car is looking great!! I've always really liked your car and its my goal to eventually have the paint/body work look that clean and nice looking on my car. Good luck on finishing it up
Old May 23, 2009 | 09:14 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Thanks Man
Old May 24, 2009 | 11:15 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
looks good, lots of cleaning involved I bet... under hood looks great. (make sure you put a grommet on the hole where the red wire is running through)
Old May 24, 2009 | 11:19 AM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Transmission: TurboHydramatic 700R4 4 speed autom
Axle/Gears: ?
Too Nice, if only I could be on that level.
Old May 24, 2009 | 01:43 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Yea about a weeks worth of cleaning just to get the floors ready for painting. My arms are still sore but its going to be worth it. Yea my grommet was nasty, try to find another one.
Old May 24, 2009 | 01:45 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Thanks Man
Old May 29, 2009 | 07:34 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Well I finally got the underside of the car done. It was more work than I thought it was going to be. I now have the piece of mind that the underside of my car will never rust.
Old May 27, 2010 | 12:24 PM
J.Prock's Avatar
What paint did you use on the under side of your car? I was planning on starting that today on mine
Old May 27, 2010 | 04:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
What is mounted in the tunnel?
Old May 27, 2010 | 04:38 PM
one92rs's Avatar
Car: SOLD!!!!!
what kind of torque arm mount is that
Old May 27, 2010 | 04:56 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
It's a Jegster torque arm. I ran one for a long time and liked it.
Old May 27, 2010 | 08:28 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
yes you are correct. It is a jegs torque arm.
Old May 27, 2010 | 08:29 PM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
It is called KBS Coatings.
Old May 28, 2010 | 02:24 PM
J.Prock's Avatar
I sanded all the rust down then put that navel gel on the rusty spots let it sit for like an hour then cleaned it with water then cleaned it again with brake cleaner. THen I sprayed that rust tough stuff on it stops rust surposedly I think I got most of it. Should I be in the clear?
I still have a big streak to sand and paint but I got the vast none rusty area covered
Old May 29, 2010 | 01:02 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
What did you use to clean it?
Old May 29, 2010 | 01:12 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
It looked insanely good before too. Kinda stoked to see what it'll look like after!
Old May 31, 2010 | 08:33 AM
street_carnage's Avatar
Car: 89 GTA
Engine: 5.7L
nice work, cant wait to see pics with the motor back in
Old Jun 6, 2010 | 04:54 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Brings back memories!
colton_carlson
Mar 8, 2019 12:21 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
Firebird sweden
Aug 16, 2015 05:02 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Street Lethal
Aug 12, 2015 11:33 AM
