WARNING!!
Old Aug 6, 2001 | 10:18 PM
un4givin89's Avatar
WARNING!!
DON'T MIX CASTROL SUPER HEAVY DUTY TOUGH TASK DEGREASER AND SIMPLE CLEAN. THE TWO ARE NOT A GOOD COMBO WHEN CLEANING YOUR ENGINE.
I WAS SPRAYING THE THING DOWN GOOD AND NEXT THING I KNOW ALL THE PAINT IS COMING OFF MY AIR FLITER AND THE ENGINE AND ALL THE CHROME OR ALIMUNIUM IS TURING WHITE AND THE HOSES GOT FUNKY WHITE **** ON THEM, TRIED WHIPING EVERYTHING OFF AND HOSING IT OFF AND THEN THE PAINT CAME OFF MORE AND THE HOSES STARTED MELTING.
JESUS H THIS IS NOT GOOD. HAS THIS HAPPENED TO ANYONE?? MAYBE I USED TOO MUCH??
Old Aug 6, 2001 | 10:47 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Thanks for the warning man!
Later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Aug 6, 2001 | 10:51 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
sounds like a delemna. You might want to start by removing caps lock on your computer anyway, that castrol stuff will peel paint away by itself when its not diluted. Your supposed to dilute it when working on painted surfaces. And it's never a good idea to mix chemicals. Some of the products of mixing certain chemical can be highly hazardous to your health.
Sorry, i can't really think of anything to really help you here, but at least you'll never do that again...
Eric
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Old Aug 6, 2001 | 11:20 PM
LeftTurn1LE's Avatar
That sucks! I hope you can get the mess cleaned up with out too much hassle. Good luck.
Old Aug 7, 2001 | 01:00 AM
Drew's Avatar
next time read the bottle. Castrol superclean, etc eat aluminum, rubber, plastic etc...
It didn't have anything to do with the mixing of chemicals.
Old Aug 7, 2001 | 10:00 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yep, I found out myself that Castrol is strong stuff. I thought it would be equivalent to Simple Green. Nope. Fortunately I was using it under the car when swapping in the T5 so what it did doesn't show.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Aug 7, 2001 | 10:06 AM
un4givin89's Avatar
I used castrol before but heres what I did wrong, see when I used it before it was in the bottle already diloted for you right, but I bought one of those big 2 gallon refill things and I didn't realize I had to dilote it. HEHE, pure concentrate.
Old Aug 7, 2001 | 11:29 AM
Camaro_hunter_d's Avatar
well sounds like you learned a good lesson on do not mix chemicals and read the directions/instructions first... sorry for the mess you made though. I use simple green all the time to stip down dirty engine blocks.. stuff works great when the block is left overnight and the next mourning take it outta the 55 gal drum then nothing but clean metal leftover. ready for prep and paint.
Old Aug 7, 2001 | 01:25 PM
un4givin89's Avatar
you let it soak in a 55 gallon drum?? Humm.......... better just ignore my ideas before I get myself into more trouble.
Old Aug 7, 2001 | 07:29 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Looks like un4givin89 has found a new solution for those of you who want to strip your painted rims down to the bare metal.
Buy the gallon size Castrol apply heavily to the rims and hose off!
No scraping, sandpaper, and countless hours spent.
Hmmm.....
Anyone willing to give it a try?
Or ya think it would pit the rim??
Old Aug 7, 2001 | 09:18 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
sunbitz,
actually theres no pitting at all. i have been using the pure concentrate on my rims for about the past 2 months. theres almost no paint left on them, but theres no pitting either. (if anyones wondering why i did this, it's cause im either gonna polish them, or ditch them here in the fall.)
Eric
Old Aug 8, 2001 | 10:27 PM
zee28's Avatar
Car: 86 iroc
If you got this stff on your hoses(rubber) I would replace them or atleast keep an eye on them .Some chemicals can break down the rubber and your radiator hoses could burst when they build pressure.Just a thougt
~mike~86 IROC-Z
Old Aug 12, 2001 | 09:42 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Unless you're degreasing a John Deere tractor Castrol Superclean is the most god-awful product on the planet. Don't even come within 10 feet of your car with this product. Under the hood and including the wheels there is just too much aluminum to mess up.
I agree the "fine" print suggests caution but it should be printed in bold letters. Castrol gives the impression that it is a good degreaser and what gets the "greasiest" on our cars......... the engine.
89 formula TPI
Sep 8, 2015 08:00 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
theshackle
Aug 22, 2015 06:52 PM
Bryan F
Aug 18, 2015 02:28 PM
