Hit the under side with a scrub brush and some simple green.
Old May 14, 2010 | 12:47 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I was bored. I figure now would be a good time since the 12 bolt is waiting to go in. It worked very well. That simple green is good stuff.
Old May 14, 2010 | 01:00 PM
camaro42's Avatar
Car: 1988 camaro sport coupe
Engine: 350 (400 sb in the works)
Transmission: 5 speed Manual
Re: Hit the under side with a scrub brush and some simple green.
Very nice and clean! So glad it's spring so work like this is worthwhile.
Old May 14, 2010 | 01:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
As if this car needed to be any more clean.... Looks great!
Old May 14, 2010 | 01:15 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Yea, I got issues. Haha. I plan to have the 12 bolt in by late Sunday. I'm hoping to feel a big difference going from 2.77's to 3.73's.
Old May 14, 2010 | 03:32 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
I spy some grime on your shocks, you're slacking
Ever think about an undercoating, like a bedliner type material for the underbody?
Old May 14, 2010 | 03:43 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
very nice! stupid question but was the undercoating already removed before you did this? and how long did it take you? and is there anything you should be careful to not spray or scrub on? I bought one of those big bottles of oomph from k-mart for like 2bucks originally 8 or so hoping to clean up the underside some time. only thing is i gotta get the car moveable first!
Old May 14, 2010 | 04:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I've done the 2.77 to 3.27 then to 3.42's on bolt on L98 and its been a big difference each step. 2.77's to 3.73's will be reallly really fun Hope to change my 99 TA from 2.73 to 3.73.
Old May 14, 2010 | 05:52 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
You will man. you will not be disapointed, i went from 2,73 to 3,73 and shaved halfed a second off my 1/4mile times
Old May 14, 2010 | 05:53 PM
Twin_Turbo's Avatar
Wow how clean, everything here rusts if it's clean and bare like that
Old May 14, 2010 | 09:34 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I don't know what was under your car, but I had the Rusty Jones beeswax undercoating on mine. Simple Green worked great at dissolving it, but it would have required a lot of work to get everything. I found Gunk Gel engine degreaser, sprayed the undercarriage, let it soak and hit it with a pressure washer. Here's my results.
before:
After:
I forgot to mention that the right side was done manually with a rag and mineral spirits and took all day. I got a much better clean with the Gunk. I did have to use some Simple Green and a clean rag to wipe any residue left after the Gunk cleaning and this was the result.
Old May 15, 2010 | 04:10 AM
Car: 1988 IROC-Z
Engine: 427 SBC
I'm having a heck of a time removing that grime on them. The shocks are the only suspension pieces left that are stock. They work fine, but I'll most likely buy new ones. I doubt I'll undercoat it. I really like the way it looks now.
I don't believe so. I'd guess it just didn't come out of the factory with any undercoating. It was just dirty. Some parts required more scrubbing than others. But before I even started, it was pretty darn clean under there to start with. It just wasn't shinny or as bright as it is now. It took about 4 hours. I used a 50/50 mix of simple green and water. There was really nothing to watch out for when doing it. It's pretty much all hard lines and stuff under there.
That's good to hear guys! My cars been screaming for gears ever since the H/C/I swap. Not to mention it was a coin flip as of late if the POSI was going to work on the 9 bolt. I did buy these though for the new 12 bolt:
That looks excellent! I don't know if it didn't come with undercoating, or if it was removed at one point. But when I got under there, it was just dirty.
I don't know how many of you heard of this wax: http://www.autogeek.net/collinite-in...r-wax-845.html
But it is literally the strongest, longest lasting wax I have ever used. My buddies and I put a coat on our cars before winter. And it will last 6-7 months through a cold, wet, salty Buffalo winter. My car is a weekend warrior that doesn't even see rain. I'm confident putting a layer of it under the car now while it's clean will last quite a while.
Old May 15, 2010 | 05:27 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
that feeling you'll get is you slapping yourself in the face going "Why didnt I do this sooner?!" lol car looks clean!
Old May 15, 2010 | 08:37 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Looks pretty sweet man, looks like a new stock underbody iroc....
I Just spent 270$ on POR15 products (paint suit, brushes, 2 quarts POR15, marine clean, metal ready, gloves, etc.) and im going to do this cleaning first, and then do a full underbody undercoat with POR15 semi-gloss black.
Old May 15, 2010 | 09:26 AM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Wow thats clean! Same with SCOTTMOYERs picture
Old May 17, 2010 | 07:59 AM
87_Injected's Avatar
Car: 2010 2LT RS
I need to do that sometime!
Old May 17, 2010 | 01:28 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
sick, thats clean.. do you ever drive that thing? LoL
Old May 17, 2010 | 09:45 PM
Red90IROC's Avatar
Car: 1991 Trans Am
Engine: 5L TPI
Looking good. Simple Green is excellent stuff, especially when combined with a couple well-chosen brushes. I use it to clean the rear 'bowls' of my aluminum rims a couple times a year. To me an aluminum rim isn't really 'clean' unless the non-face section is too. (Maybe you're not the only one with 'issues' )
I love this shot of Scott's car too
My Camaro was Ziebarted by the original owner. I like the protection, but there's something really cool about being able to preserve and see a view like the above. To me it's a part of 3gen history. Maybe it'd be worth shooting it with clearcoat?
On my Camaro, I do re-apply rubberized undercoating in high-wear places like wheelhouses, as needed. Seems like a good low-budget solution, compared to more 'robust' stuff like Por15.
Old May 17, 2010 | 09:57 PM
skinny z's Avatar
Did either of those immaculate chassis have undercoating on them?
I've laquer thinnered my to death and still have about a paints thickness of the black crap covering the factory paint.
Attached Thumbnails Hit the under side with a scrub brush and some simple green.-img_4805.2.jpg
Old May 17, 2010 | 11:57 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks. I guess in the long run it was a good thing our deal never worked out. Lol. I really wouldn't be happy with 3.27's with this setup.
Lol sure do. But it's not a daily driver. I wouldn't consider the car as having low miles anymore. I got 75,200 miles on it currently.
Old Jun 9, 2010 | 07:31 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Update: All done!
Old Jun 10, 2010 | 12:29 AM
rogslayer's Avatar
Car: 92 Camaro RS
Engine: 3.1
Thats just sick, very nice looking. I wish my car was as nice as everyones here on this site.
Old Jun 13, 2010 | 08:08 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Update: All done!
are spohn swaybars bigger then the stock iroc ones?
Old Jun 13, 2010 | 08:25 AM
skinny z's Avatar
What is the most effective product to use to remove undercoating?
Laquer thinner evaporates too quickly. Varsol or paint thinner isn't aggresive enough.
I'd like to remove the undercoating but leave the factory gray e-coat.
From the picture you can see that's it's in excellent condition.
Old Jun 13, 2010 | 09:04 PM
I used a putty knife to remove the majority of the gunk under my car, then "purple power" to clean up what was left, worked for me. Once you get the 'thick' stuff off, it comes off easily enough
Old Oct 5, 2010 | 11:07 AM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
How do the new gears feel?
Old Oct 5, 2010 | 11:21 AM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
wowwwwwwwwwww you guys are lucky!!! lol if only my underbody was that pretty. wow. ive got a weekend coming up at the body shop with a grinder and por 15. not looking forward to it but must do it before the car comes off the road in about 6 weeks. ill take pics of how it goes.
Car: 92 Camaro RS
Engine: 5.0L
let alone the fact that i just spend 140 for a gallon of paint!
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Sep 4, 2015 07:57 AM
Wesly_66
Aug 26, 2015 09:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
kyleb24
Aug 15, 2015 08:24 AM
