Brighter Headlights
Car: 89 Camaro Iroc-Z
Engine: 383 Stroker
Axle/Gears: 3:27
Brighter Headlights
I was wondering if it is even possible to find HID headlights or just anything brighter than the stock ones as a matter of fact....I live in the middle of nowhere Idaho and it gets pitch black out here and my lights just aren't doing the job as much as they used to...if anyone knows where to get some bright HID's or an easy mod that would be amazing.
Car: 87 GTA
Re: Brighter Headlights
You haven't run a
at all, have you? There is LOT of threads about brighter headlights. From drop ins like Sylvania Silverstars (which I use & live in the middle of nowhere) to HID retro fits.
at all, have you? There is LOT of threads about brighter headlights. From drop ins like Sylvania Silverstars (which I use & live in the middle of nowhere) to HID retro fits. Thread Starter
Engine: 383 Stroker
Axle/Gears: 3:27
I have been searching around...it's just I would like some input on what would be recommended and so forth
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
There are some ideas in these threads,that may help.
Alicat.
https://www.thirdgen.org/forums/afte...vy-camaro.html
https://www.thirdgen.org/forums/afte...eadlights.html
https://www.thirdgen.org/forums/afte...onversion.html
Alicat.
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Just installed silstars in my bird. I noticed about double the vision range as compared to new hlogen replacements. When the brights are on I can see much much farther.just to see the differance I installed a single bulb while standing in the original lights beam path the new light totally overpowered the stock type beam. I give them my vote 100% and vouch for them
Car: 91 CAMARO RS
Engine: 305 TBI
Transmission: AUTOMATIC
Car: 85 Trans am
Engine: 350 carbed
The replacment bulb only I tried in my dads taho dident really do much same for my volvo big rig. But the glass style replacment bulb/lense unit on my chevy pickup toyota mr2 and firebird have been utterly impressive. I'm not sure what the differance is but sidee by side with either of thos bulb only replacments is blown away by the sealed glass housing style and the lenses weren't fogged or damaged
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You could also try what I did. I replaced the inner hi-beam only bulbs with a pair of outer hi/lo-beam bulbs. Grabbed some connectors(and the bulbs too actually) off a Camaro in the local U-Pull and wired them up. Cost me all of $4 for 2 bulbs and connectors. I also installed relays for both hi and lo beams to power them directly from the battery, not off the headlight switch. Now its like driving with my hi-beams on all the time, even with just the lows on.
I live out in the country too, and every day to get home from work I have to drive down an unlit forest-lined road thats full of deer. I also installed a set of driving lights last summer, and they helped, but nothing like what I have now. Only problem I've had is every once in a while a driver coming the other way thinks I have my hi-beams on since all 4 lights are on and flashes their lights at me. I just flash them back to show them it really is my lo-beams
Car: 91 CAMARO RS
Engine: 305 TBI
Car: 91 CAMARO RS
Engine: 305 TBI
Car: 1992 Camaro RS
That is so freakin sweet I never thought about that, is it legal and can you make a diagram im a tard when it comes to wiring sometimes. Also you know how if you pull and hold back the hi beam lever it illuminates the high and lows until you let go and then just the highs or on. Can you wire it to where the lows/high are on at the same time when on high beam. Cool mod.
As for legality, it will depend on your local inspection laws. I did include a switch in the diagram that will turn off the inner 2 low beams if you need it that way to pass inspection. Just put it somewhere hidden.
Yes, only a slight change would be needed to have all the hi and lo beams on at the same time. Might produce too much heat though, shortening bulb life.
Car: 87 GTA
I put Silverstar bulbs in my fog lights too.
I made my lights 10x brighter by just adjusting them correctly for once.
Silverstars are the minimum any vehicle should have and when I first installed them, correctly adjusted them, I had cars flash their lights at me on the highway on a regular basis. I didn't think they seemed that bright though.
Euro Hella H4 conversions from Summit are the best for a non-HID setup - Better beam pattern. Intially cost about 3x as much as a pair of Silverstars but as long as the housing doesn't break all you have to replace is the H4 bulb. I don't know if you can find decent H4 bulb for cheap though.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Car: 91 CAMARO RS
Engine: 305 TBI
Diagram attached below. I have made so many changes to the electrical systems on my Camaro that I long ago started diagramming everything just so I know what I did and can troubleshoot any problems.
Axle/Gears: Stock.
I've just bought these for my camaro.Once I get them and get them in,I will post my thoughts on them.
Alicat.
http://cgi.ebay.com/ebaymotors/82-92...Q5fAccessories
Alicat.
Car: 1992 Camaro RS
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
im gonna be toying with hids in a few weeks, since ive had so much down time at the shop we're all just working on our own stuff for now, and since i just finished my stereo...i need to move on to lighting lol im gonna polish my tail lights first but the HID bug has hit me hard, i have trouble seeing in the city some times because the dim street lights throw off my headlights and its normally raining, with crappy paint on the road, HID's seem to be the only solution
Car: 87 GTA
Alicat.
Alicat.
Axle/Gears: Stock.
.I looked at the silverstars as well,thought about it,and went the other way.I hope i've made the right decision as the shipping to me was $75 US
.If their really no goodI might try retrofitting some Hid's.
Alicat.
Car: 1986 IROC T-TOP
Transmission: 700-R4
I bought a kit that lets me run all 4 lights on in high on my 97 chevy truck. I imagine it would be easy to install in a Camaro too. Just a relay, tapping into the light wires, connecting to the battery, and a ground.
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
HIDs all the way ! do the conversion and pick up a good HID kit, plug and play and you wont ever go back to a reg bulb again.
Car: 1992 Camaro RS
I'm eventually going to replace my outer low beam bulbs(55 watts), with high beam bulbs(65 watts) on my truck. Then wire them so all 4 stay on while the highs are on. I just need to pick up the bulbs, bulb connectors, and a relay.
Car: 1992 Camaro RS
That, and what I did cost me less than $10 for everything. Including the bulbs which I pulled from a local junkyard.
Car: 89 IROC Z28 Vert
Car: 1992 Camaro RS
