Best Cheap Upgrades
Old May 22, 2011 | 08:06 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Best Cheap Upgrades
What was the best cheap upgrade you put on your car? Where di dyou get it? What did it cost? How long did it take you to do?
Post pics as well
Old May 22, 2011 | 08:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Best Cheap Upgrades
the best upgrade is a good CLEANING . a good cleaning of EVERYTHING , EVERYTHING even the underside . good luck .
Old May 22, 2011 | 09:02 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I'm in work on painting my turn signals with Nightshade paint. That way when the lights are not on, they appear black (my car is black also) yet they still illuminate in the correct color to maintain legality. I have 'em painted but haven't installed them on the car yet. I'll post pics when I do. I spent about $10 including the paint.
Old May 22, 2011 | 10:27 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I used the nightshades...it came out okay on the turn signals...I changed the side markers to black ones and I like that..but my favorite was installing the bowtie grille. It cost me 68 dollars, installed in about an hour. (cause I painted behind it, and I had to drill holes for the clips to hold the grille in) But I love the way my front end looks. But I also have not taken a picture of it yet!
Old May 23, 2011 | 02:12 AM
AKcamaroAK's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
Get a pic of that, I'd LOVE to see it dude
Old May 26, 2011 | 11:06 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Cheap upgrades? Are we talking performance, appearance....Some peoples vision of cheap is much different than others view of cheap. I dont like CHEAP upgrades, most of the time any CHEAP upgrade I see that has been done is not actually an upgrade at all.
In my opinion, the best cheap upgrade on my car was shaving and smoothing my engine bay. For me it was cheap because I own a Engine stand, hoist, MIG, 55gallon compressor, asst of air tools/guns.
It cost me a few weekends. Under $100 for dupont paint, catalyst, reducer, primer. About another 50$ for wire wheels, zirc abrasive pads, and flap discs, and about $60 for body filler.
Around $200 got me a fully shaved bay, and painted. To me that is cheap for what it is.
Old May 26, 2011 | 11:53 AM
karl's-92'-z28's Avatar
Car: Too many cars
Since you have a TBI car im not so sure performance wise, maybe a CAI- cold air intake, chip , exhaust. Im not sure about a TBI spacer, youll have to ask the TBI guys.
Also a upper strut bar, wonder bar, struts/shocks & a good drop.
If you can save the paint a good polish & wax.
Post some pics so we can give you a better route to take. Hope this helps.
Old May 26, 2011 | 02:32 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
first, if its got miles, spend the money to refresh your suspension - these things wear out and new shocks/struts/springs can make a world of difference. not super cheap, but can be done in stages and very noticeable
then exhaust - was lucky enough to score a catback used from a member here for under $200 and very happy with it
Old May 26, 2011 | 02:34 PM
insomniac's Avatar
Engine: 5.7 L98
i did bilsteins in the back and kyb in the front, changed the steering end to end. hmm think the springs will make a big difference? should i go oem on them?
Old May 26, 2011 | 02:37 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
nevermind, you're further ahead than i was figuring.
exhaust maybe then? you wanting performance or visual upgrades?
Old May 26, 2011 | 02:40 PM
Car: Too many cars
Go with moog if you want stock height.
Old May 26, 2011 | 02:45 PM
insomniac's Avatar
Engine: 5.7 L98
well my plan is to swap out the motor next winter, i just dont know with what yet. something that wont be too much of a headache. i hear swapping anything in from that 5.0 tbi is a real pain in the ***. the exhaust needs to be done but id have to make sure it could swap over to a new motor. but for the tbi iv heard something aboyt a hooker aerochamber axuast sounding loud. i just cant seem to find one
Old May 26, 2011 | 05:45 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
a catback will be a good start; good upgrade for any engine on these cars and will breathe right for when you go to a bigger motor. I loved the hooker catback I had on my last 3rd gen, sounded really deep without being overkill loud at idle.
the easiest upgrade from the 5.0 tbi would be a 5.7 tbi. not too much to change; same harness, slightly different knock sensor, different injectors, and a different tune. you could get away without retuning the computer, but you won't get the most out of the upgrade. more "hassle", more reward. at least that's what I'm hoping for when I get done with the headache of an LSx swap I got myself into
Old May 26, 2011 | 05:57 PM
87Proud's Avatar
Car: 87 Camaro
Engine: 305 5.0L V8 4BBL Carb.
Well here's my car with Niteshade paint on tail lights and front marker and turn lights. 14.99 for paint plus rubbing alcohol, sandpaper pad, etc. Took minutes to do, longest part is getting all your plastic off to reach the rear tail lights and then waiting for paint to dry. Then my fav was the Magnaflow cat and cat back, 380.00 for cat back and about 78.00 for the Magnaflow hi-flow cat. Still in the process of replacing all those damaged parts and getting a new paint job.
Attached Thumbnails Best Cheap Upgrades-dsc01731.jpg   Best Cheap Upgrades-dsc01735.jpg
Old May 26, 2011 | 11:57 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Other than the Bow tie grill I would have to say that replacing the old tired front turn signals with the 1A-Auto set was what really finished off the front of the car.(I also fixed the hood gap in the photo)Heres a link to the set = http://www.1aauto.com/1A/HeadLights/...PP00008/271776
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
wanext
Oct 6, 2015 12:18 AM
customblackbird
Oct 1, 2015 04:30 PM
Damon
Sep 26, 2015 04:29 PM
