center cap emblem glue?
Old Aug 10, 2011 | 11:55 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
what kind of glue holds on our center cap emblems? or what is it and where can i get it? thank you
Old Aug 11, 2011 | 12:04 AM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: center cap emblem glue?
Do you need any new center caps? I have one in EXCELLENT condition. I just cleaned it off today, and looks like new. Not scratches on the emblem or anything. As for the glue problem I was not aware that the center caps used any glue.
Old Aug 11, 2011 | 12:13 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
you can use Black RTV... that is what I used on my 4th gen wheels... to cover the ABS emblem with the Phoenix
Old Aug 11, 2011 | 07:01 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I just used whatever high strength glue I had. Works fine.
Old Aug 11, 2011 | 07:50 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
I used crazy glue. Still stuck on after 8 years.....
Old Aug 11, 2011 | 09:54 PM
Engine: L31 350
i could use one yes, but depending on price and if its the right one for my car we might be able to work on somethin
Old Aug 13, 2011 | 09:52 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
On the IROC caps I use the yellow trim cement. Really holds and doesn't damage the plastic.
Old Aug 13, 2011 | 10:29 PM
Car: 1992 Camaro RS
NVM.
Old Aug 13, 2011 | 10:31 PM
Car: 1992 Camaro RS
NVM.
Old Aug 13, 2011 | 11:35 PM
Engine: L31 350
grrrr, its black , i need grey. thanks anyways bub
Old Feb 16, 2012 | 07:33 PM
Engine: L31 350
Just installed mine with 3M plastic and emblem adhesive, will it hold?
Old Feb 17, 2012 | 03:07 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
i had used jb weld with no problem.
Old Feb 20, 2012 | 09:02 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
picked up emblem adhesive at the parts store
Old Feb 20, 2012 | 09:37 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Can't go wrong with a two part epoxy. Will never come off! Mix equal and get the 5 minute stuff. It will glue anything together forever!!
gta892000
Aug 11, 2019 11:16 AM
Breazlan
Sep 25, 2015 11:20 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
