View Poll Results: January 2015 Car of the Month
Voters: 74. You may not vote on this poll
January 2015 COTM **Voting**
COTM Editor (Retired)
Car: 89 Formula 350, TTA
Car: '86 Sport Coupe
Engine: 310"
Axle/Gears: Stock 10 bolt. 2.73's
Re: January 2015 COTM **Voting**
I am truly honored to be up again. I was going to step down this month, but a 2 car cotm is no fun. Charcoal's car is great, and I've always loved John's Berlinetta! Anyways as most of you probably know by now. this is my 86 sport coupe I've been slowly restoring with my dad over the last few years. Powered by a built up small block through a slipping 700r4 and a howling 10 bolt! She's coming together slowly. Will be getting a 383 soon
and maybe I should fix the tranny and rear too while I'm at it, lol
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
You got my vote Zach! Good luck to everyone!
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Voted for CB since I seconded him before.
but all are very nice.
I also learned something.. I forgot that the Berlinetta had the larger holes in the front fascia are larger and the sport coupe have smaller.. eventhough I owned a 83 SC I thought it was the other way around! weird huh?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Now I REALLY wish I would have taken a few better pics last Summer !! 'Mean Green' was stripped of every nut/bolt and the entire body was stripped to metal (firewall, door sills - everything ) and re-painted a couple years ago. From the factory it was a mild mannered LG4/auto with 3.08's, but it's been converted and modified several times since I bought it back in 92'. Most recent stats:
LT1, LT4 springs, LT4 Knock Sensor, Full Steel RR's, Composite Valve Covers
T56, Stage 3 clutch, Aluminum Shaft, 98' ZT POSI with 4.11's
LS1 Slotted/Drilled Brakes Front/Rear
Jegster SFC, 36mm front, 25mm Rear Bars,
Poly Bushings Front, Rear, Motor Mounts, & Tranny Mount
ZR1 Wheels, 275/40/17's
Dyno Don 1 3/4" Headers, Random Tech 3" Cat, Magnaflow 3" Cat-back
Duel Lier Siegler Conteur Buckets, custom "CAMARO" upholstery
8 Speaker BOSE, 12 Disk CD Changer
4th Gen Keyless Entry, Twilight Sentinal Rear View, AC Delete
Intelletronics Speedo (top speed 1/4 mile, ect... ), 5500 Red-line Tach
Daytona Cowl hood, 87+ Rear Fin / 3rd Brake Light, 'Wet-Arm' Wipers
New Weather-Stripping
ALL power options; Even kept the factory Rear Wiper !
Couple pics:
Thanx to any and all for considering my ride to be January's COTM !
Car: 1991 Firebird
Engine: 3.1L V6
Geez, both of you have quite a bit done to your cars compared to mine. They are also cleaner overall. Beautiful cars, gentlemen!
Will post up more pictures and info on my car shortly.
Car: 1991 Firebird
Engine: 3.1L V6
Thank you for the nomination and votes everyone!
I bought the car in August of 2004 for $1500. It had a failing Maaco paint job, would shut off when coming to stops, and it was completely stock.
Functional Ram Air II hood.
Paint is Dark Shadow Gray Metallic with the nose and sail panel birds airbrushed in solid black.
Wheels are XXR 526s 18x9 with 275/35 up front and 18x10.5 wrapped in 295/35 BFG KDW2s.
Upgraded to 91-92 T/A tail lights and blacked out.
Suspension includes:
1.75" LoTek Lowering Springs
KYB struts/shocks(will be swapped out for Koni Yellows)
Founders Strut Mounts
Founders Rod/Rod Panhard Bar and Lower Control Arms
Hotchkis Strut Tower Brace
Global West a-arm del-a-lum bushings
Future Additions:
CTS-V 4pot brakes (already purchased, awaiting their arrival)
LSx/T56 swap
too much to add
Future Additions:
LSx/T56 swap
too much to add
Transmission: T-5, TH350, T-5
This is the first time I had a hard time picking, but I have such a soft spot for LT1s.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
John in Ri badass ride man!
Has my vote. Sometimes a waxed bare bones car doesnt cut it! Lots of cars like that look good in photos. until you see them in person.
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
John in RI Vote.... The BADDEST BERLINETTA on the Planet!
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
All beautiful thirdgens!!!!
My nomination and vote stays with charcoal...his bird has transformed beautifully since he first had it....love his choice of styling with the ra hood, wheel/tire combo, stance, and paint and body are immaculate!!! Good luck man!!!!
Car: 1985 IROC / 1986 SC
Engine: 305 TPI / 2.8 MFI
Transmission: 700R4's
Axle/Gears: 3.27 Posi / 3.42 Open
Voted for John's car. Not only is it one bad *** ride, having personally known John for a number of years, John is one of the nicest people you will ever meet as well.
Car: 87 IROC Z, 2010 2LT
Engine: 305 TPI, 3.6 V6
Transmission: 5-Spd, 6-Spd
Axle/Gears: G92 3.45
Car: 87 Camaro
Engine: Small Block 400
Axle/Gears: 4.10 9"
Also voted for John, as he has been a plethora of information, as well as provided a lot of the hard to find parts on my build. Good Luck John!
Linson
Oct 1, 2015 09:50 PM
Linson
Sep 21, 2015 01:08 PM
