Nite Shaded my Turn Signals, Check it out, and give your opinions, bad or good
Old Dec 29, 2001 | 02:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have to put some on the web, for now I'll just post a couple of attachments.
The side ones didn't come out quite that good, but oh well.
Attached Thumbnails Nite Shaded my Turn Signals, Check it out, and give your opinions, bad or good-irocblackouts.jpg
Old Dec 29, 2001 | 02:25 PM
Car: 99 Formula
Axle/Gears: 342
side view
Attached Thumbnails Nite Shaded my Turn Signals, Check it out, and give your opinions, bad or good-irocniteshade.jpg
Old Dec 29, 2001 | 02:34 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Looks good, I approve!
The guy who owned my car before me did the tail lights with that stuff. I will probably do the turn signals too.
Attached Thumbnails Nite Shaded my Turn Signals, Check it out, and give your opinions, bad or good-rsback.jpg
Old Dec 29, 2001 | 02:35 PM
wataru's Avatar
I like it. I was thinking about doing that to the bird. Now i just might.
Old Dec 29, 2001 | 02:42 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
What do you use to do that? Just black paint? Did you take it out of the bumper, and did you paint the back or front side of the light? I've never really understood this painting tailights thing either. But, I'm only 15 so I wasn't around 'in the good ol days'. Can someone enlighten me? I'd light to do this stuff, is it legal everywhere? Do your lights still shine through?
Old Dec 29, 2001 | 02:44 PM
Blue502's Avatar
Yeah, that does look real good. Side markers too, however anyone ever thought about getting a set of clear ones and smoking those? The yellow always seems to show through and make the tint look muddy.
Old Dec 29, 2001 | 02:50 PM
Car: 99 Formula
Axle/Gears: 342
Here's a pic showing everything.
I used Nite Shade, got it from Summit, just taped the surrounding areas and sprayed. The clear side markers is a good idea, so the yellow doesn't show thru.
Yes, the light does shine thru, but like my brake lite blackouts, I believe this stuff is also illegal, but I haven't been pulled over yet for the brake lights. Probably should check local laws.
Attached Thumbnails Nite Shaded my Turn Signals, Check it out, and give your opinions, bad or good-irocniteshade2.jpg
Old Dec 29, 2001 | 02:53 PM
RSFreak's Avatar
Its not black paint. Nightshade is a spray tint. Think of it as clearcoat with a tint to it. The guy who did mine did a sloppy job and got lots of runs that can be seen up close. I would redo mine if I could afford another set of tail lights (hint, hint, Blue502! )
Old Dec 29, 2001 | 03:08 PM
Blue502's Avatar
John, you don't need another set of lights, yours are already ruined with the spray tint, so just redo yours. Sand the lenses with 1000 grit, then 2000 grit, and respray. Then mask off the lenses and paint the grid with Krylon semi-flat. Should be like new. If the 2000 isn't fine enough for you, you could always polish with 3M Perfect-It first, plus you could probably clearcoat over the tint before doing the grid if you want.
If after all of that you still think you need a set of taillights, we can talk at the gathering...
Old Dec 29, 2001 | 03:11 PM
RSFreak's Avatar
Cool! Thanks Lance.
Old Dec 30, 2001 | 03:01 PM
Prime's Avatar
Car: 91 Firebird Vert
Engine: LO3
Yea I like mine. Done them about 3 to 4 years ago.
Old Dec 30, 2001 | 04:58 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Here's mine...
Attached Thumbnails Nite Shaded my Turn Signals, Check it out, and give your opinions, bad or good-hood-up.jpg
Old Dec 30, 2001 | 06:27 PM
un4givin89's Avatar
Heres mine on a black car, if you can see them Sorry for the bad pic..
Attached Thumbnails Nite Shaded my Turn Signals, Check it out, and give your opinions, bad or good-sidemarkerblacked.jpg
Old Dec 30, 2001 | 06:28 PM
killer305's Avatar
is that **** leagal?
Old Dec 30, 2001 | 07:52 PM
duke_mushroom's Avatar
To do that do you prep like you would on a body panel or is there another way?
Old Dec 30, 2001 | 08:17 PM
un4givin89's Avatar
I just cleaned them with rubbing acohol and soap real good and painted mine.
Old Dec 30, 2001 | 08:56 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Looks good Mark!!
Old Dec 31, 2001 | 12:25 AM
Mark305TBI's Avatar
Rather than taping anything off or stuff like that, I just pulled the entire assemblies out. That way I could set 'em up where the stuff wouldn't run or drip and I didn't have to worry about overspray.
Old Jan 1, 2002 | 04:22 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
No it is NOT Illeagal
Old Jan 1, 2002 | 05:25 PM
HrdRockA4305's Avatar
Mark you car is like almost a twin to mine! Other than you have the better rear wing, I don't really care for mine, but it'll be replaced when budget permits. That tint dosen't look bad on it either. Hmm got me thinkin... I'd like to see what clears look like too, must check all options of course before doing anything.
Old Jan 1, 2002 | 05:31 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
That looks bad, well the good bad. Hell it look great!! How much is that spray tint??¿¿
Old Jan 1, 2002 | 05:38 PM
Car: 99 Formula
Axle/Gears: 342
www.summitracing.com search for nite shade , $6.95 I believe.
Old Jan 1, 2002 | 07:53 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I've looked at the pics like four times and can't decide if I like it. I sure don't hate it. It looks good, but I don't know if I'd do it with my car.
Old Jan 3, 2002 | 12:07 AM
AmorgetRS's Avatar
Looks awesome!!
Old Jan 3, 2002 | 12:45 AM
FiReBReTHa's Avatar
pics are in my sig if any are intrested, ive yet to get new ones....
specialized
Jun 18, 2022 09:26 AM
InfinityShade
Aug 22, 2015 08:00 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
