This car is ruined
Car: C1500
This car is ruined
http://www.bumpstop.com/lowrider/low55.htm
Everybody email this guy and ask him why he did that to a camaro.
Dat car is tight, I an't wait to do this myself
sarcaism
I sent him in in depth detail of his sin and how his blastful acts of sin are sending him to hell where he will be forced to drive a gremlin
sarcaism
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I can't speak for the guy but, as a guess, I bet he did that because it's his car & something like that appeals to him.
The car doesn't seem all beat to he|| so I can't see where it's ruined. Actually it looks to be in better shape than both my cars.
I don't are much myself for the wheel choice but, at least they aren't gold....
That does look dumb but I have seen worse. There was a Camaro up in northern Pennsylvania that had 4 wheel drive installed in it(I guess b/c they get alot of snow). It had huge tires and sat 4' off the ground
! Should of took a pic of it.
! Should of took a pic of it. Trending Topics
Car: C1500
! Should of took a pic of it. TGO Supporter
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
A functional suspension is no longer present in that car. Therefore, it's ruined.
Car: '89 Firebird
Engine: 7.0L
My first thought was that he got the pieces mixed up when he put the model together.
Actually, it's a clean car and hopefully will some day be reclaimed.
Car: '89 Firebird
Engine: 7.0L
! Should of took a pic of it. Originally posted by un4givin89
As for me, I think that car is complete crap, and I'm pissed every time I see a muscle car ruined.
Engine: TPI 305/ v6
I'd consider the car below much much more ruined than that camaro Even though the suspension is still intact, not much of the rest of the car is...
I believe the law is, once you drop the cash & sign the title, the car is yours to do whatever pleases you as the owner & not others who believe 3rdgens were cast from a block of gold.
Deadbird, I'd rather repaint a car than try to put a stock suspension back in after removing 10 pumps and 16 switches. That crap isn't exactly a direct bolt-in. I'm sure you gotta make some semi-permanent modifications that won't be easy to undo.
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
this is how I see it...he can change the rims anytime he wants...but he likes them,
Im sure he doesnt drive around with it bumpin like it is in the picture, he can leave it slammed, put it at stock height, or even raise it, and drive in any position, which of us can do that, not to many, if he put some ROH rims on there and wasnt bumpin 90% of us would love it and compliment his car anywhere we saw it and never knew it had "6 switches"
and if its so bad what were you doin trollin the site to find a camaro, must have appealed to you somehow
Engine: TPI 305/ v6
Jim, while I can't disagree that some sort of mods have to be done to install hydrolics, the car itself appears to be in fairly pristine shape (aka, there seems to be some pride taken in the appearance of the car & a hack hasn't been doing work to it).
The pic I posted however, requires much more than just a simple repaint...
Amount of time & work involved to both, I'd place my bets on the camaro being an easier fix but, I have the advantage of knowing just how much of a total heap the (mostly) blue 'bird is (I was going to buy it at one point b 4 I got up close to it)
A wheel change on the camaro & it would probably be tough to guess it had the hydro's.
Car: C1500
A friend sent me the link to the site. I saw a camaro in the list and clicked on it. I didn't like what I found.
It looked like it was a great car before he did those terrible suspension mods. Maybe one day it will be rescued and given it's suspension back, but it will probably end up being unrecognizable as an fbody though.
Thats cool, also I didnt wanna come off as an A-hole, that was meant light hearted
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Re: This car is ruined
I think he did that in response to the "Camaro or Firebird" poll...
Rob
Rob
Linson
Aug 21, 2015 02:12 PM
. Just what every 'vert needs, hydralics to twist its body into a pretzel.
