Valve covers
Old Aug 26, 2019 | 01:31 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Valve covers
So I picked this setup up for $20. Wasn't sure where to place this but, if I install them, is the only way to add oil through the dipstick? Could I add oil through the breather?
Old Aug 26, 2019 | 07:52 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Valve covers
Yes, but depending on how they've been installed on the valve covers, it may be a slow process to pour oil through them.
Old Aug 26, 2019 | 07:02 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Valve covers
Gold anodized Moroso covers with Offy breathers...classic stuff!
Old Aug 26, 2019 | 07:26 PM
NoEmissions84TA's Avatar
Re: Valve covers
Where do you plan to put your PCV valve? If you add a hole for the PCV, then you can also use that hole for the oil fill.
Ideally though, you want your PVC valve in one valve cover and the breather in the opposite one for proper engine venting.
Old Aug 27, 2019 | 04:14 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Re: Valve covers
Ok thanks. I'll just drill a hole for the pcv valve. Might do it on the side where I can get a funnel in.
Old Aug 28, 2019 | 01:15 AM
Re: Valve covers
Drill carefully. If the bit grabs the sheet metal, then it will mess up those nice valve covers. And use the proper PCV grommet.
Old Aug 28, 2019 | 03:49 AM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: Valve covers
A step up bit might work best here. Used them many times on sheet metal race car bodies with no problems. But as NoEmissions said proceed with caution. These should be steel and may drill slightly harder then the aluminum sheet I’m referring to.
Old Aug 29, 2019 | 03:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Valve covers
Better be sure to install a baffle under that PVC hole too !!!
Jaime-TA-84
Aug 8, 2009 09:11 AM
Kebos86
Aftermarket Product Review
Jun 13, 2009 05:53 PM
BtownZ28
Aug 30, 2008 11:15 AM
PneumaticTire
Sep 19, 2004 09:50 PM
nblanchard
Aug 5, 2002 09:37 AM
