oil fill through pcv
Old Aug 29, 2008 | 11:24 AM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Does anyone do there oil fill through a disconnected pcv temporarily? Both my valve covers were leaking and hacked up from previous owners so I decided to junk them and get replacements. Didn't take into consideration that new covers had no oil fill outlet. I could fab one just wondering if I could go through the baffled pcv with no ill effect.
Old Aug 29, 2008 | 11:30 AM
irok2fast4u's Avatar
Re: oil fill through pcv
yes you can if its baffled it may take a few more seconds to drain through. You do not need to blow holes in the covers it is fine alot of high end valve covers dont have a fill hole.
Old Aug 29, 2008 | 01:08 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
thats what I thought, a few more minutes doesnt bother me
Old Aug 29, 2008 | 02:37 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
i fill mine through the pcv hole too...
Old Aug 29, 2008 | 09:38 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
The question I have is where is the engine drawing in filtered air?
The PCV system has the PCV valve in one valve cover and the pipe bringing filtered air into the other valve cover.
If the valve cover has no filler cap then put the oil in where the fresh air goes in- no baffle to fight with.
The only valve covers I know of that have no filler caps are the pre-'69 models that have no openings at all.
Originally Posted by irok2fast4u
... alot of high end valve covers dont have a fill hole.
You ARE #@%*ing, kidding right?
Old Aug 29, 2008 | 10:31 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
chill buddy i think what hes refering to by "high end" valve covers are fabricated valve covers and in that case hes right.....
http://www.thewarfields.com/img/Cars...alveCovers.jpg
Old Aug 29, 2008 | 10:42 PM
Engine: 350 4BBL
Then I would say they ain't done being "fabed" yet. It's about like buying a pair of designer jeans that don't have a hole in the leg for your foot to stick out of...
on the off chance that the guy buying them don't have any feet.
Old Aug 29, 2008 | 10:47 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
im just showing a possible reason for his post. and i see alot that are solid. but for a street engine u should have a pvc valve on one side and filtered air source on the other i will agree with that...
Old Aug 30, 2008 | 12:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, it's more like buying a pair of dress pants that the tailor hasn't hemmed yet on the off chance that you might have different legs and feet than everyone else.
Old Aug 30, 2008 | 09:04 AM
you people are on edge around here. the valve covers i have that are made by edelbrock they have a pvc valve on one side and a fresh air return on the other side, but wait they dont have an oil fill hole. both sides are baffled, so i am sorry as of now i will include every detail i can so i do not make some one mad, however the ? asked was can i fill my oil through pvc vale, yes you can
Old Aug 30, 2008 | 11:15 AM
so are you saying your fresh air comes through via an air gap around your oil fill cap? if your going to get snippy dont [ut your heart before your brain pvc hole and opposite side air return have no common place to an oil fill hole three holes versus two (now i understand)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
corey8084
Sep 17, 2015 02:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
