Removal of old decals
Old May 5, 2020 | 09:16 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi,
I have the original decals which cranking and peeling. The paint in the car still in pretty good condition. I am seeking for any suggestion in how to remove the decals without damaging the pain. I am planning to replace with good quality ones. Any recommendations are appreciated!
Stay safe and thanks!
Old May 5, 2020 | 09:23 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Removal of old decals
Originally Posted by podiatra
Hi,
heat gun on a sunny day. Might be difficult since they are cracked but best change of not damaging paint.
Old May 6, 2020 | 12:10 AM
Drew's Avatar
Spray nozzle on the hose will blast them right off like they were never there.
Old May 6, 2020 | 08:16 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I like the 3M eraser wheels.
Old May 6, 2020 | 08:44 AM
podiatra's Avatar
Engine: 350 swap
thank you all! I read that wd 40 might help loosened them up and not damaging the paint? Have any of you use it before?
Old May 6, 2020 | 10:18 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
eraser wheel.
Old May 6, 2020 | 08:16 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I have a Snap On, Crud Thug that I use at the body shop. You need a pretty good air compressor to make it work, though. But it is SUPER FAST at removing decals
Old May 6, 2020 | 08:32 PM
Drew's Avatar
Am I really the only one who's blasted the decals off clean with a garden hose nozzle? I mean it's harder not to spray them off. If they're old, dry, and cracked, they usually come off leaving only the 'shadow' where they used to be adhered. Pretty sure a blow gun at 100psi would probably take them off clean if a person caught a loose edge.
Old May 6, 2020 | 09:13 PM
podiatra's Avatar
Engine: 350 swap
I think the spray nozzle deserve a try. It can’t get any easier than that. I will try this weekend and let you know.
Old May 7, 2020 | 07:26 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
3rd vote for these they work great
Old May 7, 2020 | 02:44 PM
podiatra's Avatar
Engine: 350 swap
Thanks a lot for the feedback!
be safe!
Old May 7, 2020 | 08:11 PM
dagwood's Avatar
Top Answer: 1
The Snap-On Crud Thug is an eraser wheel on steroids! But it's expensive....
I'd try a pressure washer first, then an eraser wheel of some kind.
Here's what a Crud Thug looks like. It's a bad mother hummer!
Old May 7, 2020 | 08:17 PM
podiatra's Avatar
Engine: 350 swap
I think pressure washer might do it. They are in poor conditions at least the irocz decal on the doors.
Old May 8, 2020 | 08:31 AM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
The Crud Thug. What a great name for a tool! 😂
Old May 8, 2020 | 09:53 AM
Drew's Avatar
A pressure washer will often remove failing clear coat and paint all the way down to the primer. A regular old spray nozzle on the garden hose will do the decals without harming the paint, unless the paint is completely trashed.
Jun 17, 2014 08:16 PM
MikeH
Jul 21, 2006 08:39 PM
Hawk4Me
Jul 3, 2003 11:54 AM
MotorCityMuscle
Mar 9, 2003 09:48 AM
