cleaning up engine bay
Old Apr 1, 2002 | 03:33 PM
Matt's Avatar
I have an 84 Trans Am that was equiped with A/C but since the system has died and never really used it I removed they system. Now I wan to clean up the area on the firewall. Is there just a heater box that I can put on, if so were can I order one from? There is not a salvage yard with in 200 miles of were I live.
Matt
Old Apr 1, 2002 | 04:22 PM
YRUSOSLO's Avatar
You could fabricate some sheet metal or plastic to cover up the hole. I just read somewhere on this board that you should keep your old A/C stuff because GM doesn't make that part anymore and if you toss it you will be at a big loss. Another option was to gut it and reinstall it.
Peace
Old Apr 1, 2002 | 04:45 PM
scauffiel's Avatar
I just cut out that huge part of the heater box and fiberglassed over the missing section. Works like a charm.
Steve
Old Apr 1, 2002 | 04:48 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Factory Non A/C box,
Try www.thirdgenparts.com and/or www.thirdgenresource.com GM no longer has it.
Old Apr 1, 2002 | 05:33 PM
Tas's Avatar
Tas
I heard you can get that from s10s.
Old Apr 1, 2002 | 06:51 PM
vjo90RS8's Avatar
Car: 2002 Z28
http://members.aol.com/iroczdave/pubpage.html
IROCZDAVE has the non AC heater boxes for $60, this is where i got mine.
Old Apr 1, 2002 | 07:57 PM
TBI305Camaro's Avatar
if your removing what i think your removing it will help get the pass side valve cover off and make it easier to install headers
Old Apr 1, 2002 | 07:59 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Here's mine:
Old Apr 1, 2002 | 10:05 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Hey Johnsjj2 looks like you need the A/C delete pulley. Oh, and that TPI air intake?
Clean Bay though.
I just ripped all my crap out too. Time to bust out the messy fiberglass stuff.
Old Apr 1, 2002 | 10:11 PM
Matt's Avatar
Johnsjj2: it looks like you dont even have a box there. What did you do to it?
Z28racer: is the whole on the left side just that a whole? Does some type of filter go in there?
Old Apr 1, 2002 | 10:16 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I believe that "hole" is where the blower motor will go back in.
Is that right?
I think I'm going the same route as Z did. Keep the heater screw the A/C.
Old Apr 2, 2002 | 02:07 AM
vjo90RS8's Avatar
Car: 2002 Z28
Thats what i did. Deleted my entire AC and also the heater control valve. Best mod i have done so far, cleared up so much space on the passenger side. Next i will try to find out if it is CA legal to re-locate and re-route my air deverter valve, it looks so ugly above the valve cover.
Old Apr 2, 2002 | 03:20 PM
johnsjj2's Avatar
Car: 1991 Z-28
You guys are right, I need that pulley. i just can't see spending $65 on it yet. I hardly ever drive the car. The TPI intake is there b/c I was planning on integrading it into the induction setup, but have since changed ideas. It will be coming off along with the K&N's, and I need to find a new, solid plastic cover.
Old Apr 2, 2002 | 04:30 PM
vjo90RS8's Avatar
Car: 2002 Z28
you can get the pulley for about 47 bucks (includes shipping) from gmpartsdirect.com, part number 10055890. I know when you type the number into the search, it says water pump pulley, but it is the correct part number for the AC delete pulley.
Old Apr 2, 2002 | 07:37 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Yes that is where the blower motor goes, I like it a lot, plenty of space now.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
