Ram Air Hoods
Old May 15, 2002 | 11:47 AM
Scott Fleming's Avatar
Car: '89 Trans AM
Ram Air Hoods
Can you guys post some pics of your Ram Air I and II hoods. I'd like to see a few samples so I can decide on what one I might get. Thanks.
Old May 15, 2002 | 11:53 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Here's my Suncoast hood:
Old May 15, 2002 | 12:08 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
Here's mine ASCD Hood
Old May 15, 2002 | 04:18 PM
scott's85T/A's Avatar
No offence to redraif but I dont think the suncoast hood looks as good as the ASCD
Old May 15, 2002 | 04:48 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I second that, but I like the one with bigger nostrels, like on the new Trans Ams, those are the shiznit.
Old May 16, 2002 | 09:41 AM
redraif's Avatar
I mostly went with the Suncoast because it was functional. Though, I also thought it went with the lines of front the car better. It matches the turn signal and headlight steps. It is right in line with them and fills the space completely from side to side. There is no gap b/w them, so to me it looks less like a scoop added to a stock hood. I also liked that the suncoast hood from the front was more agressive looking. To me, it looked as if that hood could have been an option for the car at the time.
I wanted the RAII style, but again it was set too far back. I wish someone had designed the RAII so that the nostrils were as far forward as the Suncoast hood, but overlaped the nose, to get the sloped look of the ASCD RAI and the RAII styles.
I agree the ASCD hood has a more finished look the way it slopes down and flows into the hood on the front. I just did not like how far back it was set. If I had the cat eyes front like the 91s, I would have gone with the ASCD hood. It definately looks best w/ that nose, since it lacks the stepped turn signal and headlight look.
Old May 16, 2002 | 10:06 AM
Snowdog 91 Formula's Avatar
I can relate to the ASCD on the 91-92 Redraif. On the earlier models, it even looks stock!
The Suncoast hood is functional, and that matters too. To make the ASCD functional it takes a little improvising, and I am planning on a design soon for it. (Similar to the SLP dual snorkel but pointing UP to the inlets on both sides as well as a way to connect to the air intake.)
Just have to get the right parts and improvise.
Old May 16, 2002 | 10:10 AM
redraif's Avatar
Improvise... My favorite word.
The way of the 3rd gen is to learn to improvise.
Old May 16, 2002 | 11:02 AM
Black85TransAm's Avatar
i was either going toget a Daytona Turbo Hood or Ram Air 2 hood, can't make up my mind
Old May 16, 2002 | 02:01 PM
Yes, you can say that since the aftermarket seems to be pursuing the 4th generation of our cars these days.
Isn't it something? 10 years after the 3rd generation of F-Bodys, there are those of us that continue to improvise.
I think that is a good thing! Look at how many cars that are still around that are around the same age as our cars.
Rex Orr is interested in what I am designing. I hope to have the prototype done by next month. I'm taking my time and doing it right.
Old May 16, 2002 | 04:05 PM
Rage13's Avatar
Car: 89 Firebird
what is it that your designing?
Old May 16, 2002 | 04:21 PM
redraif's Avatar
I believe planning to make the ASCD hood functional. I'm sure people will be lining up at you door step if you do. Just remember to put something in there to deflect the rainwater. SunCoast put a piece in that deflects the water. Seems to work. Been in 3 rainstorms so far and the filter looks good.
Old May 16, 2002 | 05:59 PM
82Trans Man's Avatar
how much hood clearance does a Ram Air hood give you for the air cleaner if the ram air isn't made functional??? Thanks James
Old May 16, 2002 | 06:23 PM
I have a 1" TBI spacer, a Holley 670 CFM TBI unit on top of that, a non-drop 14" base and a 3" K&N open element on top of that!
(That means there is a lot of room by the way....)
I hope that helps you out.
Old May 17, 2002 | 09:18 AM
1986redbird's Avatar
AHH YES,
my favorite saying ----- "necessity is the mother of invention"
Old May 18, 2002 | 12:45 AM
maverick544's Avatar
Whats with you cant make a RAII fuctional, I've seen plenty of them functional. I think I'm going to get my V6 the RAII and fuctional. The only thing is I will have to improvise with the maf sensore.
Old May 18, 2002 | 11:47 AM
Car: '89 Trans AM
Thanks for the pics, lets keep 'em coming!
Old May 18, 2002 | 03:44 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
sweet
Old May 18, 2002 | 04:23 PM
Nasty_Bird_'90's Avatar
whats the difference between the RA I and RA II hoods?
Old May 20, 2002 | 10:25 AM
redraif's Avatar
The RAI is the one styled like mine and the ASCD, with the single hump.
The RAII is the one like the current (now axed ) Birds, with the dual humps.
Old May 20, 2002 | 10:35 AM
redraif's Avatar
I think the reason they say you can't make it functioal is that the box is hard to seal on that style. To be truely "functional" as a "Ram Air" style it has to seal the box so no air escapes. My hood has a indention the exact same size as the filter the 2 meet up and seal. So any air that comes thru the snouts is forced into the filter. On the RAII style there is not the filter sized indention in the hood. Unless you make your own seal it is more of a cold are induction that a true funtional RA.
1992 Trans Am
May 10, 2023 07:19 PM
Mutillator
Sep 17, 2015 04:38 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
bryan623
Aug 10, 2015 11:33 AM
