how can i fix my sagging doors
Old Jun 27, 2002 | 03:23 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i was wondering if there is anyway i could fix the doors on my 84 trans am?? they sag and squeek when i close the door and i have to close them pretty hard
Old Jun 27, 2002 | 04:05 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
See http://www.3rdgensolutions.com/orders.html.
This kit has sorted my problems completely!
ANDYZ28 is the man!
Do a search on this and you will find many pleased customers! And, no, I don't get any commission.
Andy.
MdFormula350's Avatar
You will need new door hinges, run a search on that and i belive some people on here listed down where to get them.
Before u run out and buy some i would make sure that the bolts are all tight around the area where the hinges connect to.
to use that one site u need to erase that last period at the end where it says html
Old Jun 27, 2002 | 08:39 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I believe the hinges are welded to the door from inside the door.
Thanx,ANDYZ28
Old Jun 28, 2002 | 12:35 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Order Andy's new greasable hinges, I have them installed, and they are terrific. The entire car has less squeaks and rattles!.
Cheers
Richard
Old Jun 29, 2002 | 10:23 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
yepp, Andy's kit is good.
Old Jul 13, 2002 | 09:26 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
I would either get new doors or get the hinges
Old Jul 14, 2002 | 12:03 PM
iroc22's Avatar
Yeah....lets go out and buy new doors because they're sagging.
All you need to do is buy new pins and maybe a hinge. And as stated above, make sure the bolts around the hinges are tight.
Old Jul 15, 2002 | 04:03 AM
CD MaroMan 91's Avatar
definently get andy's kit
Old Jul 15, 2002 | 02:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
He might also want to look at the rust on the bottom edge of the door; if it's extreme, replace the door, AND the hinge.
My passenger side door is really bad; I've been putting off on replacing the door (it's badly rusted, too) until I do the 1/4 panel. But, for kicks, I opened the door, grabbed the bottom by the latch, and lifted up and down. The door moved a good 3-4 inches! Wow.
Old Jul 15, 2002 | 03:04 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Bushings/pins are dead
High Perf Pontiac December will cover this on a third gen GTA. Your bushings and pins are probably wasted. I am not familiar with Andy's kit, but new bushings and pins are about $15.00 from the dealer, or you can also buy the inner hinge halves already loaded from Year One.
We just replaced the bushings and pins in the bottom hinge. Now the door has no sag and closes with 2 fingers. Dec HPP comes out 9/24.
Old Jul 15, 2002 | 06:28 PM
ANDYZ28's Avatar
Car: 1982 Z-28
The door hinges on ALL 3rdgen F body cars are WELDED to the door from inside the door. This makes hinge replacement very difficult.
Only the LOWER door hinge can be serviced with replacement pins & bushings.
The UPPER door hinge is a one piece design, and cannot be rebuilt. It must be replaced as an assembly buy cutting it off the door. I can tell you this is no easy task.
This was the only method of correcting the root cause of sagging doors on many of these cars. Until I developed a repair kit for the UPPER door hinge.
Many members have used my kit with great success. Now that I have a "truly" greaseable upper dorr hinge repair kit. The hinges can, and will last indefinitely.
I will be interested to see how "High Performance Pontiac" solves this problem with the UPPER door hinge. Remember the door has two hinges.
Thanx, ANDYZ28
Old Jul 16, 2002 | 11:06 AM
TA's Avatar
TA
Axle/Gears: 9bolt
Bushed
Andy/everyone
Our upper hinge was fine, we didn't do anything with it. The dealer sells a kit with 2 shorter pins for the upper hinge, you have to cut the old pin out or grind away the swedge, which is a major pain in the butt. The new short upper pins stay in by gravity. It didn't look like the most attractive solution, so we didn't screw with a good hinge.
Perhaps if you decided to advertise your product line in HPP, more people would see it and know about it (including us at HPP), and we would use it in future stories.
If you would like to do a new products release (no charge) on this product, please send me an email and we will work out the details.
troya@mcmullenargus.com
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
SG91camaro
Sep 5, 2015 10:27 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
