Water in my car
Old Jul 14, 2002 | 01:15 AM
brandin98's Avatar
Water in my car
When ever it rains light or hard i get water on the floor in front of the passangers seat!! I dont think my t-tops are leaking and it is only there in front of the seat not on the seat or any were else?!?!?!?!
Old Jul 14, 2002 | 06:58 PM
MdFormula350's Avatar
it could come from the window!
is there a trail of water on the floor?
the trail might start at around the door window seals and then make alittle trail of water on the floor towards the seat.
it could also be the t-tops, just because the water just leaks on the front passengers floor doesnt rule out the t-tops leaking, my t-tops just leaked on the rear before i fixed the leak with silicone.
Old Jul 15, 2002 | 08:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It could also be the seal at the base of the windshield.... a glass shop should have some kind of leak detector...
Old Jul 15, 2002 | 09:13 AM
ATOMonkey's Avatar
All of mine have done that. I'm absolutely convinced that it's the vents in front of the windshield. They collect water and it dribbles into the HVAC and then onto the floor. Know what the worst thing is. If you can see it that means that the insulation can't soak up anymore! Might want to take a look under there and see what kind of water/rust damage you have. Then again, you might not want to know.
Old Jul 15, 2002 | 03:00 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Your heater core might have burst.
Old Jul 15, 2002 | 03:29 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
This sort of problem has come up recently on this board and the problem I and most of the others discovered was here.Underneath the heater blower motor is where the wheel arch meets the firewall.This area is very inaccesible and water,leaves,mud etc can accumulate here.Over time this can rot the firewall quite badly.Because of the above inaccesibility and the fact the carpet hides the inside,it can rust a lot without you knowing until water runs in.I literally put my whole hand through the hole in the firewall.I do hope your problem is not as bad as this as the repair involved is a bitch.
PS.It can also happen on the drivers side.
Old Jul 15, 2002 | 03:46 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
Yup, check below the blower motor....I did and found a ton of debris that collected over the years. Rotted a hole in my firewall....I don't know how to fix it.......any suggestions?
Old Jul 15, 2002 | 04:05 PM
Car: '92 RS Camaro
Transmission: TH400
The 2 options I can think of are as follows:
1.mig Weld a new piece of metal in.This is a bitch of a job as it means removing part of the dash and working in a very awkward position.(I did this).Use corroless or por-15 on the repair,and for added security blast cavity wax on the trouble spots.
2.Cut the metal back to clean if possible and use loads of corroless or por-15 around the whole area.Rivet a piece of aluminium mesh over the hole and repair with fibreglass paste or matting and resin.Finish as above(I've also used this on other repairs).Pour yourself a large glass of booze and pat yourself on the back.
PS.Whenever any repair is undertaken make sure it is rustproofed from BOTH sides as you'll be back to where you started.
Old Jul 16, 2002 | 08:03 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
That happens to me occasionally but I find that it comes from under my roof console.
Old Jul 18, 2002 | 07:22 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
My leak ends up on the driver's side floor Well, i'll have a garage in a month so I guess it doesn't much matter.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
