3rd gen lowered
Old Feb 23, 2003 | 10:57 PM
  #51
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
i was woundering how they drive lowered??? any stiffer of a ride???? and how much do you think i could lower mine with out beeing to low. just want a nice look with out a hard ride i have 16 inch wheels btw...link to pics below
http://community.webshots.com/user/paulstoy71
http://community.webshots.com/user/paulstoy86
Old Feb 23, 2003 | 11:06 PM
  #52
acidboy's Avatar
Quick question. How much ($$) are lowering springs. I'm on a somewhat limited income (thus is the curse of being a high-school student).
Old Feb 24, 2003 | 10:53 AM
  #53
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
springs liek 200 bucks, plus shocks.
intrax on Mine:
Old Feb 24, 2003 | 12:35 PM
  #54
XThree's Avatar
Car: 91 RS
Transmission: TH 700 R4
CustomX what are those about a 1 inch drop?
Um soo.. if you get lowering springs you can't use factory shocks anymore?
Old Feb 24, 2003 | 12:37 PM
  #55
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
2 inch drop.
Most aftermarket springs are of a higher spring rate, thus your stock shocks wont have enough dampening to properly control the springs movement.
Old Feb 24, 2003 | 12:41 PM
  #56
XThree's Avatar
Car: 91 RS
I c,
so I guess I better plan on putting in the QA1 shocks at the same time I get teh lowering springs.
I heard with a 2 inch drop you will have problems if you go to larger wheels/tires Ive been checking into that. seems like If I go 1 inch drop I could comfortable go to 17ich wheels, with 235's
Old Feb 24, 2003 | 01:18 PM
  #57
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is my before and after pics of lowering,
Old Feb 24, 2003 | 01:38 PM
  #58
nosaint's Avatar
Car: 1986 Trans Am
Belltech spindles 2" front, 1 1/2" back with springs
17 x 9.5 all around with 275's only minor rubbing on full turns
Old Feb 24, 2003 | 02:19 PM
  #59
XThree's Avatar
Car: 91 RS
Zepher, Great before and after pics dude!
nosaint ..oh you used dropped spindles ... I was wanting 1 1/2 or 2 front and back lowering springs, but its good to know with 2inch you can run 275's.. whats the width of the tires? 50? 40?
Also I love those wheels! what are they?
Old Feb 24, 2003 | 02:49 PM
  #60
scott's85T/A's Avatar
http://www.nosaint.ca/
Try this.
Old Feb 24, 2003 | 03:34 PM
  #61
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Ok here he is in 89 with a stock stance...
  #62
redraif's Avatar
here is 99 with sagging stock stance
Old Feb 24, 2003 | 03:37 PM
  #63
redraif's Avatar
Now with the Eibach prokit. And the ride improved greatly. The progressive springs make bumps and handled much more secure and comfotable. Less harsh banging as the stockers bottom out over bumps. Its a mushy floaty feel now!
Old Feb 28, 2003 | 09:43 PM
  #64
XThree's Avatar
Car: 91 RS
Redraif what size wheels and tires are those? that looks like a perfect fit.
the Eibach pro's are a 1in drop front and back and the Eibach Sportline are 1.6 front and 1.3 back for a 91 Camaro, and more for other cars according the eibach's website.
Old Mar 3, 2003 | 09:52 AM
  #65
redraif's Avatar
I am running 17 in rims with 245/45s... Now because my car is a V-6 its front end did not weigh enough to let a level stance...The nose was way jacked up. We prayed and cut 1/2 a coil. It worked and the ride is fine...We used a cut off wheel little by little to cut & to control the temperature. Last thing I wanted was to ruin the spring by heating it and changing its properties. A V-8 car should have no problems with the springs. Now the car did have to settle for a month or so before it looked like this. Springs always have to seat and settle...
Old Aug 3, 2008 | 08:26 AM
  #66
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Re: 3rd gen lowered
Originally Posted by RU-QWIK
what is that hood fiber os steel?? wer you baught it?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
