How to get door spring in?
Old Sep 11, 2002 | 12:33 AM
JaDeCaMaRoRS's Avatar
Car: Camaro RS
Engine: 3.1 V6
I was putting a new door pin in my passenger door, and inorder to get the old one out I had to jam the other spring slightly out of the way, however it ended up popping out right after I got the pin out. I have no door spring now which sucks for our big heavy doors, everytime my girl tries to get out the door slams back in her face.
I tried channel locks but the ones that I can get the spring to compress enough in cant fit into the small space by the door hinge. Anyone know how to get this spring back into the door hinge assembly?
Old Sep 11, 2002 | 01:06 AM
Saywhut's Avatar
you need one of these
Old Sep 11, 2002 | 08:21 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
if you dont want to buy a spring compressor...the ghetto way to do this is get some bailing/tie wire cut a few pieces loop it through the center of the spring, then start tisting the ends together as you twist the wire shortens compressing the spring...install, untwist, cut wire out...voila! just be careful you dont let it pop out and put an eye out
Old Sep 11, 2002 | 10:22 AM
Saywhut's Avatar
Heh, I'd forgotten that, saw it posted the last time we discussed this. It was suggested to compress it in a vise, then wire it up, etc.......
Sounds like a plan to me, if you don't have the tool.
Old Sep 11, 2002 | 11:33 PM
Car: Camaro RS
Engine: 3.1 V6
I think I will get the tool, hey never know when I may need it again!
Old Sep 11, 2002 | 11:42 PM
Saywhut's Avatar
Thats what I did, bought it for one use, have used it more than once since, it'll fit lotsa GM doorsprings.
Old Sep 12, 2002 | 06:45 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Here is an image of the door spring compressor tool in use.
Thanx,ANDYZ28
Old Sep 12, 2002 | 11:42 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
put the spring in a vice, and compress it, then use the zip-ties, or bailing wire. After you stick the spring back in, just release it carefully. That method worked for me at least.
Old Sep 15, 2002 | 08:29 PM
Vettetrax's Avatar
Car: Camaro Z28
Transmission: auto
some of you people are just genious:hail:
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
SG91camaro
Sep 5, 2015 10:27 PM
