underneith hood
Old Sep 25, 2002 | 04:57 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
underneith hood
hey,
i was wondering about this. underneith my hood is insulations i guess it is. it is somewhat falling down in the front. could i remove this and leave it off for good or do i need to leave it on
thanks
bub
1987 camaro sport
305 5.0L V8 carb
Old Sep 25, 2002 | 05:11 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Thats an interesting debate, Actually I have seem many people remove the insulation with no problems that I am aware of.
What it does is a couple of things, most importantly it protects your hood from the heat of the engine so not to wreck your paint. Another thing is it absorbs some of the engine sound when the car is running.
New hood insulation usually runs about 35-40 bucks or so from GM.
Its your call, I will NOT say do it tho...
John
Old Sep 25, 2002 | 06:13 PM
Rage13's Avatar
Car: 89 Firebird
i don't think it would be a problem to remove it.. i don't have mine and my hood paint is fine, you can hear the under hood noises a little better tho...
Old Sep 25, 2002 | 06:28 PM
FLYNLOW92rs's Avatar
Think of it this way....
How hot does the hood get sitting in the baking sun all day???
It seems it would be cooler under the hood......
Just my .02, but it would be safer to probally keep it on or buy a new one....
Unless you keep the engine below 160* all the time...
Old Sep 25, 2002 | 07:03 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
My friend has an 88 IROC with no insulation and he's had no problems with the hood paint yet, even when the fans weren't working.
Old Sep 25, 2002 | 11:05 PM
sllt1776's Avatar
Car: 89 Iroc-Z
good question. i just took mine of for the same reason. i guess the questions is how often do you drive it...and what conditions
Old Sep 25, 2002 | 11:27 PM
LarsZ28's Avatar
Be careful if you have a fiberglass hood.. I have no insulation in my engine bay, and the paint has started to bubble on the hood. (it is the 82-84 Fiberglass hood)
Old Sep 25, 2002 | 11:56 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Mine fell off years back, and my once-black-hood turned to an oxidized gray blotchy hood from the heat and the bad GM paint...I don't know if better paint jobs hold up to the heat better, but I just put a new insulation pad on mine. 25 bucks through GM, plus some dollars in new clips is worth the trouble.
Old Sep 26, 2002 | 01:01 AM
Is there any alternative to the black insulator for aftermarket hoods(fiberglass)???
Some sort of spray you can put on their that acts like the insulator???
Old Sep 26, 2002 | 01:28 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Insolation under the hood
If ya got a 305 or a 350 just get rid of that crap it just gets in the way plus everybody can hear your engine grrrrr louder and better
and thats "Intimadating" to the rice racers!
Old Sep 26, 2002 | 07:58 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Mines been off for about three years now and I have no problems. If you have the K&N cone filter you can hear it sucking in air alot more.
Old Sep 26, 2002 | 10:22 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
One other thing to remember is that it acts like a fire blanket if the motor catches on fire. The plastic pins will melt and the insulator drops in hope that it can smother the fire out.
Old Sep 29, 2002 | 05:17 PM
bubbakutz's Avatar
Engine: LG4
ok, thanks guys for the input. i tink ill play it safe and keep the stuff on
Old Sep 29, 2002 | 05:40 PM
Sounds Good
Also remember that you can place that picture in your signature instead of upoading everytime you post.....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
