85 firebird nose and foglights?
Old Oct 2, 2002 | 04:33 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Has anyone done thios? i want to put fog lights in my nose but i dont want to get a 82-84 nose or put them underneath , and suggestions? photoshopped pictures? Thank you
Old Oct 2, 2002 | 09:09 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Actually get a 91/92 Nose. They have the foglight cutouts. You will have to move your turnsignal lamps to the space provided in the nose. But that will give you a factory look without the need for ground effects from a later year and without the look of the 1982-84 nose. Hope that helps.
Old Oct 2, 2002 | 09:31 PM
acctually im not a big fan of the 91,92 nose i really like the 82-84 nose but this is my fav
Old Oct 2, 2002 | 09:58 PM
87WS6's Avatar
Well you could always get a Trans-AM nose and the ground effects and rear bumper for your car. But that seems like alot of work for just doing foglights. I wouldn't suggest a chop job simply because they don't usually look good.
Old Oct 2, 2002 | 11:25 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Fog lights and nose
Well believe it or not the rubber guards on your nose is removable
and can be modified for fog lights but you would have to add "L"
brackettes for the foglights and made openings 2"x 20" or depending on actual width of nose.
Old Oct 3, 2002 | 03:56 AM
Jyrx's Avatar
Car: Firebird
Transmission: th700
Well with a little custom work you can do this, and you dont have to move your turn signals.
Old Oct 4, 2002 | 08:02 AM
AT4 T/A at work's Avatar
I'm going to be doing this real soon too. I'm putting an '86 Trans Am nose on my '84. I don't think it's necessary to change ALL the ground effects just because I want a new nose! When I took all the stuff off the donor car, it looks like a real easy job too. Since I've taken off the front fenders as well, I won't even have to drill to make the front GFX fit.
Old Oct 4, 2002 | 01:34 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Boy, you ain't kidding. And anyone who suggests simply replacing your nose with a '91-'92 nose has obviously never shopped around for one. You're looking at around $400 for one, IF you're lucky enough to find one. I would say forget the foglights because that front clip isn't very condusive for that. Sorry, dude.
Old Oct 4, 2002 | 08:30 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Skatepunk,
Do you realize how RARE your hood is??? If I am not mistaken you have an S/E with the front hood louvers, without the rear hood louvers...
Cool... I think that is the first one of those I have ever seen...
only made like 7500 of those cars with that hood...
back to reality
John
Old Oct 4, 2002 | 09:13 PM
Really? are you serious? cool i thought it was a cheap GTA hood .. i love the thing because im not a big fan of the rear vents. How much do these go for?
Old Oct 5, 2002 | 01:45 AM
deadtrend1's Avatar
Dude, you can get a TA nose from "www.up22.com" for liek 130 bucks.
83 Crossfire TA
Jan 3, 2016 01:26 PM
jtwoods4
Sep 3, 2015 05:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
masonta
Sep 1, 2015 06:40 PM
