4 gen dash in a 3rd gen
Old Oct 11, 2002 | 10:26 PM
ZipTriX's Avatar
I notice several people have converted from the third gen dash and console setup to the fourth gen setup. Has anyone actually make the conversion and kept their ac/heater setup? I'm thinking of doing this, but I want to keep my ac/heater, since I use them.
Old Oct 12, 2002 | 10:47 AM
widow_maker89's Avatar
Where do you live? I am currently gathering parts from a 96 Trans am...... for my 89
Old Oct 12, 2002 | 12:32 PM
ZipTriX's Avatar
Charlotte, North Carolina.
I currently have my 92 Camaro RS in the shop, and am wanting to change everything over at once, if need be. So I'm needing assistance with what needs to be done and such, so I can make out the plan and find the parts.
Old Oct 12, 2002 | 12:46 PM
FLYNLOW92rs's Avatar
ur tah sofa king we did....
Something like that contact him.....
Old Oct 12, 2002 | 01:07 PM
ZipTriX's Avatar
I read the site on that pciture you posted. That person didn't use the center vents, but instead put gauges there. This is what I play on doing.
Replacing dash and console with those of a 4th gen T/A. Maybe a 97+ if possible.
Replacing door panels with those of a the same year as dash and console.
Replacing climate control piece. I don't like the 3 gen one, plus it needs to be replace.
Also swapping motor to a LT1, which is a whole other topic.
This is what I want it too like. Any idea what year it is?
Now my main concerns are:
When changing the dash, would it be best to use the underdash ventilation from the 4th gen oppose to what I have now?
When changing the climate control, would I need to change the dash wiring? If I have to change the dash wiring, would I have the change the power window switches and such? I'm just trying to cover my ***. It would suck to find all this out, while doing it, and not having the needed parts.
Old Oct 12, 2002 | 02:17 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
very similar to the '99 camaro i've been looking at
Old Oct 12, 2002 | 08:06 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
hey do you have to redo your speedo when you do this. is this hard. also do the bolts line up or do you have to drill your own. also how long does this take
Old Oct 12, 2002 | 08:56 PM
CrazyHawaiian's Avatar
Car: too many ...
Yeah the pic you posted is from a Camaro interior. The pic FlynLow posted is from a T/A. If you want the guage pods then get a T/A dash. You will have to rewire everything. Everything. Use the 4th gen ducts or build your own.
Old Oct 12, 2002 | 09:01 PM
ZipTriX's Avatar
Don't want the gauge pod. I do, however, really like the 97+ camaro interior. Is there anything else that I need to get when I pickup the dash, console and door panels?
Old Oct 13, 2002 | 12:06 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
That looks damn good...
Old Oct 13, 2002 | 12:38 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Too much trouble for me...
Old Oct 14, 2002 | 11:46 AM
jocww's Avatar
what if u have a 5 spd
Casey Meyers
Mar 2, 2016 10:46 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
